KEY NOT DETECTED
Old Jun 24, 2021 | 03:52 PM
mazenkanso's Avatar
c300
KEY NOT DETECTED
Hello, I installed LED lights in the center console and now I " sometimes" get key not detected !! I need to hold the key behind the seat to push the start button and once the car starts everything is fine unless I stop and open the door. The LED does not necessarilt have to be on when I get the key not detected. Any help would be appreciated.
Old Jun 24, 2021 | 04:14 PM
Cosworth2000's Avatar
2022 E53 AMG
Change the battery on the key and see if it still happens.
Old Jun 24, 2021 | 06:23 PM
stockbmw's Avatar
2018 C43
See if the problem exists using the 2nd key. If so, you might have crosswired the LED with the proximity sensor wire.
Old Jun 24, 2021 | 06:26 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Sounds like interference to me. LEDS can create interference.
Old Jun 24, 2021 | 06:31 PM
Andy74's Avatar
W205 2015
The key sensor is in the central console bellow the right cup holder. You could have mooved it while installing your LED. First install a new battery in your key see if it works. If not you will need to remove your console again and check the key sensor.
Old Jun 25, 2021 | 01:03 PM
mazenkanso's Avatar
c300
Thanks, I did change the battery and used the extra key, still same issue
Old Jun 25, 2021 | 01:22 PM
Again, interference. Even my garage door opener says range may be reduced by using LED bulbs.
Old Jun 25, 2021 | 04:20 PM
Andy74's Avatar
W205 2015
Check the key sensor in the centre console. I had the same issue when i installed my 10.25" screen.
Old Mar 23, 2024 | 04:29 PM
Shibin's Avatar
W205
Same issue for mine also
Have you got the solution.
And where exactly is the sensor located ?
