Replacement rim for 2015 C300 standard wheel
Old Dec 7, 2021 | 09:12 AM
cheerful's Avatar
C300
Replacement wheel/rim for 2015 C300 base model
Hi,
One tire keep leaking b/w the tire and rim (front). The tire shop says the rim is bent and need to be replaced.
How can I find the part number for the wheel/rim?
Where would be a good place to buy replacement rim?
Old Dec 7, 2021 | 11:34 AM
W205C43PFL's Avatar
The part number can be found on the rear of your rim
Old Dec 7, 2021 | 12:48 PM
cheerful's Avatar
C300
Hi,
I've attached a photo. I can't seem to find any text on it. Could you be a bit more specific? Sorry I'm not familiar with this.
It's 2015 C300 4Matic Sedan
The tire shop says I need to get a rim. Are rim and wheel the same thing?
Old Dec 7, 2021 | 03:35 PM
PaulR7's Avatar
W205
That's A2054010200 for the part number, searching for Mercedes C/W205 17 inch rim on sites like ebay et al will also yield the same result.
As for the part number, it's stamped behind on the inside part of the rim.
Old Dec 7, 2021 | 05:55 PM
W205C43PFL's Avatar
Originally Posted by cheerful
Hi,
Thanks for your follow up post, the image helps as it was able to provide important information such as the size of the wheel and the design which will all have different part numbers. I mentioned that the part number is located at the rear of the wheel which means the back side of the wheel (meaning, you need to take the wheel off your vehicle to see it). Another forum member already posted the part number before me and that is the correct number for your wheel.
Old Dec 7, 2021 | 06:37 PM
cheerful's Avatar
C300
Thank you guys!
Going to search for a place to buy.
Is it common for the wheel needs to be replaced? about 40K miles.
Old Dec 7, 2021 | 06:40 PM
PaulR7's Avatar
W205
Thank you guys!
It's not common but not unheard of either, one good bang in a mid sized pothole could do it or it could survive hundreds of them just as easily, just luck of the draw and you drew the short one.
