W205 C300 WINDOW PROBLEM
Old Jan 13, 2022 | 10:44 PM
oliwer200's Avatar
W205 2016 C300 4Matic *SOLD* 2017 C43 AMG COUPE
W205 C300 WINDOW PROBLEM *FIXED*
I have been having a problem with my rear right window. The window switch doesnt seem to do anything but the driver side window switch only lets the window go down but not up, you cant hear the window motor running when I pull the switch up. Any Ideas on how I can test whats wrong? Thanks
Old Jan 14, 2022 | 01:09 PM
W205C43PFL's Avatar
Could it be a fuse, or did you try recalibrating the windows?
To recalibrate to put it simply is to close the window and then hold the window switch up (basically lift it past resistance for 15 seconds or so)
Edit: since you couldn't close the window, try the calibration without successfully closing the windows if not it is likely a fuse or the actual button broken.
Old Jan 14, 2022 | 07:36 PM
oliwer200's Avatar
I tried looking for a fuse but there aren’t any for power windows on the fuse map. I’ll try to buy one of those tools that lights up when there is power on a connector and see if that tells me anything. The switch is getting some power as the switch has the orange light on
Old Jan 15, 2022 | 11:53 AM
W205C43PFL's Avatar
I see keep me posted.
Old Jan 20, 2022 | 05:05 PM
oliwer200's Avatar
Just replaced the window motor that wasn’t the problem.
Old Jan 20, 2022 | 07:10 PM
PaulR7's Avatar
W205
I've had that problem, my window switch was lighting up as well, turns out it was faulty and replacing it fixed the issue. The actual switch on the rear door did however work so not 100% sure you have the same issue, maybe both switches are faulty, I bought mine from AliExpress and quality is exactly the same, the light is even better than OEM.
At least it's fairly cheap on Ali to test it out: https://www.aliexpress.com/item/33041347830.html
Old Jan 21, 2022 | 06:39 PM
oliwer200's Avatar
Yeah the driver side controls work when I roll it down it rolls down but when I try to roll the window up nothing happens, I did take the motor out of the door panel and I heard a very, barely distinguishable pinging so I’m guessing it’s either the control module or it might actually be the control buttons getting some power but not enough to send the full signal to roll the window up
Old Jun 17, 2022 | 08:28 PM
oliwer200's Avatar
I just wanted to renew this thread because I figured out the problem and would like to help anyone else having a similar issue. The problem was that the master window switch in the driver side door was broken so a quick swap out fixed the issue. To remove the master switch you don’t need to take off the door panel. All you need to to Is get one of the plastic trim removal tools first remove the plastic silver trim around the buttons followed by removing the black bigger black plastic trim that’s around the buttons (colors of the bigger trim vary by interior color) then it’s as easy as unplugging and replugging the new one in
Old Jun 17, 2022 | 09:09 PM
W205C43PFL's Avatar
Glad to hear that you found the issue thanks for sharing the fix with us.
Old Jun 18, 2022 | 12:20 PM
cidtek's Avatar
C300 4Matic Tenorite Grey
Did you you source your replacement from the AliExpress link posted above?
Old Jun 18, 2022 | 01:10 PM
oliwer200's Avatar
yes I don’t remember exactly if it was that particular seller but I did purchase from AliExpress. I misunderstood the prior replies and I just swapped out the window switch on the door that wasn’t working thinking that it was that switch that was the issue but it was in fact the master window switch on the drivers door that needed to be replaced. Hope this helps!
Old Jun 18, 2022 | 10:50 PM
cidtek's Avatar
It's good to know that there is an alternate source for some MB parts.
