W205 engine noise help!
Old Oct 6, 2022 | 03:19 AM
sefru's Avatar
2017 c200 W205
Hey guys, does this sound normal? I can hear a dull knocking/ rattling noise at idle on my 2017 c200. It’s only got 37,000klms on the clock. Any help would be greatly appreciated.
File Type: mov
Old Oct 6, 2022 | 06:07 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 forum...
Old May 11, 2024 | 11:12 AM
frankonline's Avatar
C200 W205
Did you fix the issue? Im having the same
Old Jun 30, 2024 | 09:32 PM
tboland's Avatar
W205
when your gas C300 sounds like a diesel, check the serpentine belt and idler+ tension pullies. changing the 3 is an easy job that you can do yourself. They should be changed anyways after 60-70k miles
