ABS Sensor Change
Old Feb 24, 2023 | 01:09 PM
Overland7's Avatar
W205 C350 E
ABS Sensor Change
Hello. I was wondering if anyone here has changed the front abs speed sensors themselves? I need to replace the left hand one, but I cant for the life of me figure out how to get the connector out of it's socket. It's so awkwardly placed all the way back behind the suspension that it is difficult to get a good look at it. Every search on google or youtube just gives me info about other brands or generations of c class.
Videos i have found all show a metal clip you remove but dont have that, please help...
Any help would be wonderful!
Old Feb 25, 2023 | 09:09 AM
Cosworth2000's Avatar
2022 E53 AMG
Not sure if this is what you are looking for.
Found this one also
It looks like you just remove the nut and pull it right out.
Old Feb 26, 2023 | 07:38 AM
Overland7's Avatar
W205 C350 E
It's not removing the sensor that's the problem, I cannot for the life of me see the connector comes out...
This is the connector
Old Feb 26, 2023 | 09:58 PM
2022 E53 AMG
If you can get a part number.. that may also help. I see your car is a Hybrid Version of the W205 which never came to American or Canada.
Old Mar 1, 2023 | 06:29 PM
dagrappler's Avatar
2015 GLA250 4matic
For mine there is a small white plastic tab to the left of the socket. In a very tight spot, I had to hold this tab open with small screwdriver while pulling out the sensor from the socket with small needle nose vise grip. I do not have the metal ring either. Hope this helps.
