C400 Tire change question
I understand people being hesitant adding any differentials of measurements to AWD cars, but I don't believe modern AWD systems are nearly as sensitive as they are betrayed to be.
If you really think about it, if manufacturers made AWD systems that fragile, there'd be dead AWD cars littering the side of roads everywhere, lol.
Also, who knows anyone that has ever had a modern AWD system grenade itself because of dimensions? I surely haven't. I hear a lot of people and mechanics make reference to it, but I have yet to see a proven example of it.
JMO.
Good luck!
JMO.
Good luck!
That said though, I mistakenly read OP as having front left and rear left tires having issues, so there is that too.
That said though, I mistakenly read OP as having front left and rear left tires having issues, so there is that too.I just wanna know I won't destroy anything or die on the road for trying to same some cash.
You are obviously concerned, so I would recommend for you that you replace all 4 tires. Otherwise it's probably going to stay on your mind and drive you nuts, lol.
Personally I think it's not an issue to replace 2 tires on the same axle and again I sure would like to see some proof it could be an issue (not just an old repeated wives' tale), but you really should listen to your gut.
I'll add one more thing and I'll stop beating this dead horse... this is a fairly large message board encompassing all Mercedes models and has been online for many years. If this was a real issue, it would be expected to see a multitude of threads and posts filled with the 4matic horror stories of massive (or even slight) failures caused by people running new and "old" tires, mismatched tire pressures, etc., but nope, crickets.
Unless a mismatch in tire tread depth causes piston failures also, lol.
