Center Control Not Working
Old Jun 27, 2023 | 10:15 AM
Cosworth2000's Avatar
2022 E53 AMG
Hello all, I need your help. Yesterday I was driving home and lost all me driving features. No Agility control, no AMG suspension control, can't control or nav screen but I can still play music.
The the holding of the eject button did nothing, the screen did go off but came back on today - weird.
I checked the cable of the harness but I couldn't find any issues.
The plug in the picture is where the harness plugs into. It's located under the center dash.
As you can see I'M doing some checking.
I think the problem is that there is no power on this plug but signal. Where is the fuse for this plug or am I looking in the wrong way. I checked all the pins that I could reach and one, I think the top left is dead and that could be the power but where is this fuse?
Anyone else had this problem and solved it?
Let me add that I scanned the center and the scanner stated that it could not communicate with it.
Scan can't communicate, no power?
add picture of scan
Old Jun 28, 2023 | 11:03 AM
2022 E53 AMG
Any help? It just stopped working for no reason.. I was not doing any work in that area.
Old Jun 28, 2023 | 07:03 PM
W205C43PFL's Avatar
https://cimg9.ibsrv.net/gimg/www.mbw...300e9f5704.jpg
https://cimg4.ibsrv.net/gimg/www.mbw...4bbb3f9ecb.jpg
add picture of scan
You commented on that thread, hopefully that is the fuse you need? https://mbworld.org/forums/c-class-w...ml#post8805403
Old Jun 29, 2023 | 08:03 PM
2022 E53 AMG
So I had to to a wire trace and it took 2 days to look at everything; Fuse, Wire, Plugs and the Audio as well and I didn't find anything wrong. I remove all the plugs and tested them all and then I removed the center also and part everything and opened everything, even the HDD. I ordered a SSD as I'm going to copy it and put it in the Audio but I also downloaded everything about the car from AutoData which really helped me to find things including the wires.
After testing all the wires, making sure everything had continuation, and looking at which wire powers everything = the Head Unit.. I plugged everything back in, one plug at a time and boom... everything booted up and all the errors I had disappeared and the car is back to normal.
My next step will be to remove the HDD and Copy it and install it back using the Window System. From what I have read in my AutoData is that if you do remove the HDD and you do anything wrong there, Mercedes will have to update everything or say you have to pay for a new audio system and without the audio system, the controls through the center stop working, which I found weird but since all the module in the center share the same power somewhere in the network, the Head Unit can cause another module to fail communication.
Old Jun 29, 2023 | 08:17 PM
W205C43PFL's Avatar
Something like this? https://mbworld.org/forums/c-class-w...ml#post8804584
Old Jun 29, 2023 | 08:48 PM
W205C43PFL's Avatar
never mind, didn't realized you commented on that thread already.
Old Jul 5, 2023 | 11:57 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
This is weird. Got in my car today. Aftermarket screen is dead, control pad and buttons are dead, power button doesn't work. CD player is dead and buttons don't work. None of them light up yellow. But the car works like normal.
Funny enough, the media and BT music is still playing.
