2015 C400 - No Power on Acceleration.
Old Jul 10, 2024 | 07:25 PM
rsmooth's Avatar
C400
Hello all!
I could use some help on troubleshooting this issue.
I have a 2015 C400 that I've been driving around for a while that has lost a good amount of power on acceleration. I suspect the turbos have stopped working since when I floor the gas pedal, the car accelerates very slowly from what I'm used to. I'm not seeing any other issues and the car does reach highway speeds, but it just feels as the turbos are not working. No check engine light or any other codes pending. Seems like this just one day happened as the car was running perfectly.
Here is what I've done and I don't recall if this issue occurred before or after these repairs I performed:
  • Changed battery - I've heard that it's supposed to be programmed after it's been changed and I've also heard it's not a big deal if you don't have it programmed. I never programmed it after the change.
  • Changed cabin filter under the hood and both air filters.
  • Changed spark plugs.
I've been driving the car around in this state for a while now, but have a little time now and would like to fix this if I can and get the missing power back. Again, no check engine light or other codes pending and the car otherwise runs normally.
Thank you for any tips or suggestions that can help me solve this mystery.
Old Jul 14, 2024 | 09:19 AM
TwoC400s's Avatar
2015 C400 4MATIC Palladium Silver Metallic
Originally Posted by rsmooth
Hello all!
This issue started some time AFTER you changed the plugs?
As a free diagnostic step you could pull them and see what they look like. Google images is your friend on "reading spark plugs."
Your best bet is to get an OBD diagnostic tool that's capable of real-time logging of the sensors. Check your boost pressure, fuel trims, ignition retard, etc.
It is kinda weird you don't have a code, but sometimes these cars just don't throw them for low performance issues.
There are a myriad of sensors and control solenoids that could possibly be the culprit; you would be the first M276.8 motor I've heard of to have the turbos go bad.
Old Jul 14, 2024 | 10:38 PM
PeterUbers's Avatar
How are you scanning the car for codes?
youre not making boost - do you have active exhaust flaps on the c400? If so those could be toast
would love to see a log of your boost and wastegate duty, timing ....
Old Jul 15, 2024 | 12:44 PM
MatthewJ's Avatar
'15 C400 and '15 ML350
C400 didnt get any active exhaust.
First thing to check would be that the intercooler pipe hasnt disconnected from the intake causing all of your boost to "blow out".
Log of the items above would be most helpful if you have no other codes on the car.
Old Jul 15, 2024 | 02:28 PM
rsmooth's Avatar
C400
Yes, my best guess is this started happening after the plugs were changed. The plugs look fine.
I do need to look into getting a better OBD diagnostic scan tool so I can grab those additional logs. I will search on the forums for recommendations, but any suggestions?
Old Jul 15, 2024 | 02:30 PM
rsmooth's Avatar
C400
I was using a smartphone app with a Bluetooth OBD2 adapter. I'll look into getting a better tool.
Old Jul 15, 2024 | 02:31 PM
rsmooth's Avatar
C400
Thank you. I will check on the intercooler pipe.
I'm going to look into getting a better OBD diagnostic scan tool. Any suggestions while I'm looking?
Old Jul 15, 2024 | 07:27 PM
rsmooth's Avatar
C400
***Update***
I borrowed another OBD2 diagnostic scanner and well... there were definitely codes.
P0299 - Turbocharger low boost
P0236 - Turbocharger boost pressure sensor A range/performance problem
P0237 - Turbocharger boost pressure sensor A low input
P0238 - Turbocharger boost pressure sensor A high input
I'm guessing the boost pressure sensor A needs to be replaced? What do you think?
If it needs to be replaced, should I buy the part from MB or another source? Lastly, has anyone done this or can point me to instructions?
Thanks a lot!
Old Jul 16, 2024 | 07:52 AM
MatthewJ's Avatar
Do you have an aftermarket intake? There are air sensors on both intake boxes. Failing to plug one of those in may cause the low boost codes you are seeing.
There are also MAP sensors on the intake plenum. The JB4 install guide has a photo of where they are. I would double check nothing came unplugged when you did the plugs.
https://www.jb4tuned.com/instruction...tall_Guide.pdf
edit, try to get MB parts when you can. check out FCPeuro or pelican for OEM stuff.
Old Jul 16, 2024 | 03:55 PM
rsmooth's Avatar
C400
Thanks for the link to the JB4 install guide! Very helpful!
I do not have an aftermarket intake. I'll double check the sensors on both boxes and the intake plenum.
If those are good, is there a way to test each sensor? Also, I'm going to need to figure out what exactly is the "A" sensor.
Old Jul 18, 2024 | 11:53 AM
TwoC400s's Avatar
Our cars are nearly 10 years old... Replace both sensors.
Get the sensors from FCP Euro.
Old Jul 18, 2024 | 12:02 PM
TwoC400s's Avatar
Take a looked at this page.
https://automotivetechinfo.com/2022/...r-tips-tricks/
I'm pretty sure the sensors you want are labeled 28/7 and 28/6 under the engine air supply system diagram.
Old Jul 18, 2024 | 06:40 PM
rsmooth's Avatar
C400
This page was extremely helpful! Thank you!
Since there are only two, may as well replace them both as you've suggested. I'll get those ordered. I took a quick look at the engine and the 28/7 sensor on top of the manifold is easily accessible. The 28/6 sensor which appears to be on top of the intercooler looks like it's going to be much harder to reach. Any easy way to reach that one without taking off the entire manifold?
Also, what types are screws are used for both of those sensors?
Old Jul 18, 2024 | 09:10 PM
TwoC400s's Avatar
Almost everything in the engine is torx or etorx.
Probably a stubby ratchet with whatever that bolt is, is your only hope
Old Jul 20, 2024 | 06:14 PM
rsmooth's Avatar
C400
***Update***
Received the turbo boost pressure sensor today. Even using a stubby with a torx bolt attached, there is not enough space to work with. I can't imagine I'd have to remove the manifold just to reach this sensor. Is there a better way of doing this that I'm missing?
I've attached some pics with the sensor circled in red.
Old Jul 20, 2024 | 11:31 PM
TwoC400s's Avatar
***Update***
Ok, I'll give you my take... But you aren't going to like it 😂
If you need the IC to move/shift you have to:
1) remove the intake/filter piping to the turbos
2) disconnect the intake pipes between the turbos and the IC(this is BY FAR the hardest part)
3) disconnect the IC from the throttle body
4) Pop the IC off of its retention bracket
After that the IC will move around quite a bit with only the coolant loop hoses connected.
​​​​​​Coincidentally, those are the first four steps of replacing the serpentine belt and tensioner assembly.
I guess I should have replaced that sensor while I was in there.
You're going to need a set of etorx swivel sockets to get the IC pipes out (or extremely low profile etorx wrenches).
Old Jul 20, 2024 | 11:39 PM
TwoC400s's Avatar
As involved as all that sounds, it's orders of magnitude easier than removing the upper intake manifold plenum
Old Jul 21, 2024 | 12:26 PM
TwoC400s's Avatar
OK, just went out and looked at the screw. It's torx, not e-torx, exactly like the one on top of the mainfold, so you might have some options there.
If amazon is an option a low profile torx, 1/4in, pass through wrench set *should* work.
Old Jun 9, 2025 | 11:24 AM
santos31@me.com's Avatar
@rsmooth did you ever get a resolution on this?
I have a 2015 C400, in which I recently replaced the battery, I did spark plugs a while ago.
I am seeing the exact same problem. Doesn’t seem to be throwing codes yet. Wondering if these sensors solved it for you or not. Thanks!
Old Jun 9, 2025 | 11:38 AM
rsmooth's Avatar
C400
Yes...
Driver side turbocharger replacement.
Get a diagnostic done on your turbos.
Old Jun 9, 2025 | 11:52 AM
Yes...
Damn sorry to hear that, thanks for the quick reply. I hope I don't have the same problem but it feels likely.
Old Jun 9, 2025 | 12:28 PM
Cosworth2000's Avatar
2022 E53 AMG
I was reading about this problem and there is a way to test or remove.
Remove/Install Pressure Transducer for Boost Pressure Control
Old Jun 10, 2025 | 12:31 AM
W205C43PFL's Avatar
Thanks for the document.
Old Jun 18, 2025 | 07:37 PM
Just as an update - for me it seems like it was just related to the map sensors.
The car finally threw a P0106 - Manifold Absolute Pressure out of range code.
As a first attempt fix I cleaned the MAP sensor on the intake manifold and the car ran way way better - power was back and the CEL went away without clearing the code.
Since then I have ordered both the sensor for the intake manifold and the intercooler (same part number) from Mercedes, and I am going to replace both.
The intercooler one was hard to get out, I had to use a stubby wrench with a Torx bit that I cut down to be very short, and it just fit. Would have been super annoying to remove the intercooler or intake manifold just to change that one sensor.
Old Jun 18, 2025 | 07:57 PM
W205C43PFL's Avatar
