Battery failure 2015 C300 4Matic
Old Jul 25, 2024 | 01:57 PM
490822MS's Avatar
C300 4matic
FSCU coding and Programming, after my battery died overnight the vehicle was dead and now I am getting error codes how can I reset the FSCU as I cannot do it with the OBD it says errors exist.
Old Jul 26, 2024 | 10:20 AM
Cosworth2000's Avatar
2022 E53 AMG
All those errors are because the battery died and you tried to start the car and there was a little bit of power left in the system. Just replace the battery, then if your reader can erase coded, erase the codes. You must make sure the battery you are replacing the battery with an AGM battery.
Old Jul 26, 2024 | 10:59 AM
490822MS's Avatar
C300 4matic
I already charged the battery and it is fully charged, the battery is good and the car cranks, but I keep getting g these codes coming back including rhe check engine light. Does the FSCU need to be programmed?
