Slight Bend Inside Barrel Of Wheels: To Drive or Not?
Old Dec 4, 2024 | 06:47 PM
  #51
W205C43PFL's Avatar
Originally Posted by Nicholi2007
I'm going to do the free inspection at the dealer. See what they say. Either I bent them or they are using low quality weights.
I see.
Old Dec 18, 2024 | 09:21 PM
  #52
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Finally Sorted With Hunter Road Force Balancer
Evidently, a lot of wheel balancers don't have the Hunter machine.
No more issues after 4 attempts. I'll probably never use anything else. The previous guy used too much weight.
A "Hunter Road Force" balance is a more advanced form of tire balancing compared to a regular tire balance, as it uses a specialized machine to measure and correct not only weight imbalances but also radial force variations within the tire and wheel assembly, effectively simulating real driving conditions to identify and address potential vibration issues that a standard balancer might miss; essentially providing a smoother ride by detecting issues like tire runout and improper mounting beyond just weight distribution.
A regular balance only looks for uneven weight distribution on the tire and wheel while a Hunter Road Force balance measures the force variations as the tire rotates, identifying issues like tire bulges or rim imperfections that could cause vibrations.
Old Dec 19, 2024 | 10:33 AM
  #53
W205C43PFL's Avatar
Mhmm.
Old Dec 19, 2024 | 11:28 AM
  #54
Mhmm.
I only did the 3 wheels where there was counter balancing done. This method is typically used when a tech places too much weight in the wrong location and instead of correcting the mistake, adds weight to the opposite side to compensate..
It was $24 a tire. Hunter also measures sidewall stiffness variations which can cause vibrations even when a tire is perfectly balanced.
Old Dec 19, 2024 | 04:15 PM
  #55
W205C43PFL's Avatar
I see.
