Cranking Issue on W205
Old Jul 8, 2025 | 11:20 AM
Sayo's Avatar
Mercedenz Benz C200
Hi there,
I have a C200 W205 which i have used for some time. Some weeks ago after driving it for some days after a service i noted that that the car was not cranking. The dashboard is powering on with all the accessories powering on but it cant crank. From the diagonasis as attached i note that there is module which the signal is not stable. Anyone who has had this issue? Tried to supply the power direct to the starter, the car seems to crack but it cant start
Old Jul 8, 2025 | 12:12 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 forum...
Old Jul 9, 2025 | 03:51 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
-- "No crank - No start"
-- DAS shown: OK
Are you familiar with the role of "brake switch" for starting?
Use your scanner to read live switch status.
> PLAN B:
Use the key in ignition slot instead of keyless....
Old Jul 9, 2025 | 04:22 PM
Sayo's Avatar
Mercedenz Benz C200
-- DAS shown: OK
> PLAN B:
Hi, actually, have been using the keys for starting as the car doesnt have the keyless feature. Is the break switch avalailble in W205?
Old Jul 9, 2025 | 04:37 PM
BRAKE PEDAL SENSOR
I'd be surprised if W205 did not use a brake switch during start procedure.
Read SW status with your scanner.
Old Jul 9, 2025 | 04:43 PM
Sayo's Avatar
Mercedenz Benz C200
The screenshots shows what am getting from the diagonosis
Old Jul 9, 2025 | 05:18 PM
WHAT are your 2x ISM Faults ??
This may well be it!
ECU must know gear status to allow start.
Old Jul 9, 2025 | 05:27 PM
Sayo's Avatar
Mercedenz Benz C200
So do u think the ECU has a problem or the same brake switch?
