SRS Fault
Old Aug 4, 2025 | 07:55 PM
sambam2006's Avatar
GLC Coupe, S63L W222
SRS Fault
Hi all,
Looking for some advice on a persistent SRS issue with my Mercedes W205 C-Class. The car is throwing the following fault:
"Right Front Door Crash Sensor There is a short circuit to positive or an open circuit (B009615)."
Here’s what I’ve done so far:
  • Replaced the right front door crash sensor with a brand-new Mercedes part.
  • Cleared the codes using Xentry, but the fault returns instantly.
  • Visually inspected the wiring and connectors – no obvious damage or corrosion found.
    I have also checked fuses.
Still no luck getting rid of the fault. Has anyone had experience with this specific issue on the W205? Is there any other sensor, maybe I have the wrong one.
I have attached pictures :-)
Any help or suggestions would be massively appreciated before I book it into the dealer.
Thanks in advance!
Old Aug 6, 2025 | 03:20 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
TROUBLESHOOTING DOOR HARNESS
Good job getting that far!
Your door SRS sensor has an open circuit despite new part being installed.
You will need to figure where this harness connection gets bad.
Use the WIS schematic diagram. It will show you exactly where the sensor harness run.
Another hour and you should be all set.
+++ HARNESS QUESTION...
homerun by itself to SRS Module ?
or networked by solderless door module ?
Old May 17, 2026 | 11:01 PM
Borkox166's Avatar
Originally Posted by sambam2006
Hi all,
Thanks in advance!
Hi Sambam2006, my GL is having the same issue and i have done the same stuff you have done with out any luck. I wanted to know if you were able to fix the issue and what was the cause of this problem. Thank you for your help!
