Hi all,
Car details:
Symptom
Very specific situation:
No warning lights, no limp mode, all other shifts feel normal.
What’s already been done:
Recent full ATF service at Mercedes workshop:
However:
Behaviour is unchanged after the service.
Questions
Thanks in advance for any input from people who’ve dealt with similar 9G behaviour.
https://imgur.com/a/E7rxt9z here’s a video of what the car does
Car details:
- 2018 C 220 d (W205 T-Model)
- OM651 + 9G-Tronic (725.0)
- ~107,000 km, full Mercedes digital history
- ATF + filter were never changed before the recent service
Symptom
- ~80 km/h in 6th gear, Comfort mode
- Stronger throttle → kickdown 6→4 up to ~3500 rpm
- I then fully lift off
- Gearbox upshifts 4→5
- Right after engaging 5th, with no throttle, there is a noticeable jolt and a small RPM blip
- New pan with integrated filter
- ATF to MB 236.17
- Level set by overflow method with Xentry, at correct ATF temperature
- No leaks, no fault codes in TCU
However:
- No standstill / gear adaptation done in Xentry
- Only a short teat drive was perfrmed
- Workshop says “not completely normal, but not a big problem, just monitor it
Questions
- Has anyone with W205 C220d / 9G-Tronic had a similar 4→5 jolt after kickdown + full lift-off (with RPM blip, no errors)?
- Did standstill adaptation / gear adaptation in Xentry improve or fix it for you?
- In your experience, does this sound more like:
- normal 9G quirk,
- TCC / torque converter lock-up behaviour, or
- early valve body / mechatronics issue?
- As long as there’s no slip and no codes, is this usually safe to live with, or would you treat it as something that should be addressed sooner rather than later?
