im going crazy with this car. ecm wont communicate with ANYTHING in the car.
The main thread talks about the V1.0 (version 1.0), the V2.0 is what has all the coding and features.
That said, if all you need is the scanner: https://mbworld.org/forums/e-class-w...onal-more.html
Why do you consider that the battery needs to be "registered"?
As you may easily find out, the U codes are not Fault Codes.
If you can't communicate at all with a scanner, I'd be suspicious of ECM damage or another module bringing down the CAN bus. You're going to need a shop that knows Mercedes well or a dealer.
