Problem with W206 USB-C port
Recently I purchased a new W206. Due to material shortages I was not able to purchase induction charger. To my surprise the delivered car has only one (literally one) USB-C port. As I took Mercedes dash cam I need to plug in the external storage to only available USB port. In this case I have no option to charge my mobile unless I remove the external storage for the camera. I tried to multiply the number or USB ports by plugging in USB hub but it does not work. MBUX clearly says that USB hub is not acceptable.
Have you faced an issue like that and managed to solve this problem?
I found something like Dual Go USB Type-C pendrive but I am not sure if it provides power and if a mobile can be charged while the pendrive is plugged in.
Link to thread discussing this: https://mbworld.org/forums/c-class-w...usb-ports.html
