Engine oil drop
Received 2,831 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Did you take the measurement at an incline or decline? Are you sure it was showing maximum before? Half (between) the min and maximum line is supposed to be the normal level, you don't want to go above maximum or go below minimum, there is also no reason to fill it all the way to the maximum line from what I gathered.
