C-Class (W206) 2021 to
2019 -> 2022 radio issues, etc
Old Sep 14, 2022 | 03:11 PM
jeff360's Avatar
2020 C300
I tried this on another forum without success - I was hoping someone here might know:
I recently traded in a 2019 C300 for a 2022 C300, and have run into a handful of small "quality of life issues", which have changed from the old car to the new one. I'm curious if there's a fix, or "it is what it is"?
Radio Unit:
  • If you use Sirius there are hundreds of channels to scroll through, so you need to create favorites. Except in the 2022 car, after saving 20 favorites it says the memory is full. I never ran into this issue with over 40+ favorites in the prior car.
  • The scroll wheel on the 2019 C300 allowed you to the scroll through radio stations (and see what was playing) , while still listening to your current channel. It would only change the channel if you "settled" on a new channel and stopped scrolling the wheel. This was a great way to browse channels. With the removal of the scroll wheel, is this feature now gone?
  • In the 2019 car, the volume change wheel used to change the volume in the smallest allowable increments. When I "swipe" the volume pad on the 2022 car, it causes a much larger and undesired change in volume. Is there any way to set or change the amount of volume change that is registered when swiping the volume pad?
Thanks!
Old Sep 15, 2022 | 02:44 PM
js_cls's Avatar
There is still a button that will show the list of channels. It looks like three lines on top of each other.
Below the screen, the volume slider which has a plus and minus, they are actually individual buttons. If you press the plus/minus once it will adjust by one.
Old Sep 21, 2022 | 12:23 PM
jeff360's Avatar
2020 C300
thanks for the reply! is it really impossible to save more than 20 favorite radio channels??
Old Sep 21, 2022 | 12:29 PM
js_cls's Avatar
Not sure because I don't use the radio, I use Spotify always, and even if I did, I don't think I'd know more than 20 different stations that I'd like.
