C218 CLS63, 2011 - 2019
when to service our cars
Old May 2, 2012 | 09:36 AM
TectiteE's Avatar
MGT, 12 CLS63 Launch
I have a launch 12 cls63. I'm getting mixed reaction on when I should service my car. i currently have 4800 miles on it.
Old May 2, 2012 | 09:49 AM
pgordon888's Avatar
2014 GT-R; 2014 GL 350 BTC
If your car has the limited slip diff you should have had the fluid changed on that at 1875 miles. Oil change at that point is not required but I had it done anyway. Next service is at 10,000 miles. All of this is in your mb Maitenance schedule you should have received when you bought the car.
Old May 2, 2012 | 10:12 AM
TectiteE's Avatar
Originally Posted by pgordon888
If your car has the limited slip diff you should have had the fluid changed on that at 1875 miles. Oil change at that point is not required but I had it done anyway. Next service is at 10,000 miles. All of this is in your mb Maintenance schedule you should have received when you bought the car.
i'm pretty sure i have the lsd but not possible. it should be on the sticker right? guess if i do have it i better get the fluid changed asap.
Old May 2, 2012 | 10:35 AM
pgordon888's Avatar
You should have a sticker on your front windshield about it if you have not removed it yet. I would also check your build sheet or window sticker if you don't see a sticker in your front windshield. If you lost all of the above they can allways look it up by vin number at the shop or you can crawl under your car and check - I can see my diff pretty clearly even without a lift.
Old May 2, 2012 | 12:18 PM
TectiteE's Avatar
Just curious what did you pay for the change? My dealership has a history of over charging
Old May 2, 2012 | 12:52 PM
pgordon888's Avatar
$170.
Old May 2, 2012 | 01:00 PM
Saeedg48's Avatar
2009 CLS63 AMG
if you have the limited slip differential you'll need to do the flush on the fluid. i also did my oil change at 5,000 miles. then another at 10,000. i think it's all personal preference but the standard is every 10K, i like to do the first a bit earlier followed by the second.
Old May 5, 2012 | 10:08 AM
TectiteE's Avatar
looked at my sticker and guess i don't have the lsd. Weird cause i thought all launch edition cls's had them.
Old May 5, 2012 | 01:37 PM
pgordon888's Avatar
Time to think about the Renntech LSD upgrade.
Old May 11, 2012 | 12:45 AM
Mr. Smokes's Avatar
2012 CLS 63 AMG "Launch Edition"
oddly, the launch edition has every option except the LSD. wtf
