C218 CLS63, 2011 - 2019
'Auxiliary battery malfunction' on startup - 2014 CLS63S
Old Dec 23, 2015 | 11:23 PM
Heisenberg's Avatar
2020 S63 Coupe, 2006 Hummer H1 Alpha, 2018 McLaren 720S, 2022 Porsche 911 TurboS, 2022 Tesla Model X
Had the main (engine compartment) battery die recently, it was replaced by roadside. It failed spectacularly overnight, car wouldn't start and was giving me less than 10v when I hooked up a charger.
Now I'm getting a 'auxiliary battery malfunction' error sometimes, not always, when I start the car, a 2014 CLS63 S. I've checked the trunk battery (for ECO, I think) and it reads 12.9-13v with the car off and disconnected, so isn't dead and is getting charged.
So does the CLS63 have a third 'auxiliary' battery - maybe the small transmission backup battery like some of the E-Class models have ? I know it is hidden below the dash on those, but thought it was only used in cars with the steering column shifter stalk. The CLS63 obviously has a console shifter, although it is really just an toggle lever so functionally is probably similar to the stalk shifter.
I'm sure the dealer would fix it under warranty if I bought it in, but if it just needs a cheap 12v lead acid battery with standard connectors, I'd just buy one and install myself. But I don't want to take a bunch of panels off, if it isn't in there...
Old Jan 1, 2016 | 02:18 AM
evansw220's Avatar
'01 S500 AMG Sport, ABC,Distronic,Rear Side Shades // '10 E350 P2, Pano, BLK/ALM,4MATIC Sport
Eco Start/stop battery is called the Auxiliary Battery.. They tend to fail due to high internal resistance...
Old Dec 4, 2017 | 05:28 PM
delirium's Avatar
C350
I got an auxiliary battery malfunction too. So, do I replace the battery in the trunk or do we have a battery in the dash as well?
Old Dec 5, 2017 | 07:27 AM
kponti's Avatar
E63
As far as I am aware we only have two batteries, main one under the AC air inlet under the hood and second accessory one in the truck.
I just changed both of mine recently and those were the only two batteries MB gave me options for
