C218 CLS63, 2011 - 2019
2012 CLS63 PP fan running constantly
Old Feb 1, 2017 | 03:58 PM
JDMAP1's Avatar
W222 S550, W218 CLS63, W166 ML550, Titan, Sentra
So today is 80* here in Dallas...went to get in it and as soon as the car registered the key fob the cooling fan kicked on immediately and loudly... it continuously ran on HIGH the whole time driving to Starbucks and back. Any one else have this problem?? Car only has 46K miles
Old Feb 1, 2017 | 04:36 PM
JDMAP1's Avatar
Originally Posted by Plutoe
You have an issue with your fan controller and or the system--find someone with factory or equal diagnostics and then you do the fixing!!
FAN EFFN TASTIC!
Old Feb 1, 2017 | 05:05 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Is your ecu tuned?
Old Feb 1, 2017 | 05:18 PM
JDMAP1's Avatar
Originally Posted by shardul
Is your ecu tuned?
yes! Eurocharged tune....currently having issue with the tune (going on a month now) fluctuating temp gauge so I'm curious if that's the case, but why just now???..... and throwing CEL P2093 (camshaft position actuator control circuit high bank2b)....they are working on fixing the issue tho
Old Feb 2, 2017 | 03:14 PM
TTMerc's Avatar
2014 CLS63 S
A fellow DFW CLS!! The temp thing I had an issue with on my 2012. The issue was from my K&N when first installed had a ton of oil on it which gummed up the sensors. I cleaned out the intake and sensors and all was good. Also check the ambient sensor in the grille. As far as the CEL check your driver side rear cylinder head. There will be a wiring harness that goes to the sensor. There's a bulletin for that sensor leaking oil and messing up some things. If you are local I can check it out really quick and see if we can get it resolved without the dealer being that you are tuned. Hope that helps!
Old Feb 2, 2017 | 10:36 PM
JDMAP1's Avatar
I'd love that. I appreciate the help in advance.
Old Oct 8, 2017 | 04:25 PM
firasmp3's Avatar
2012 Cls63 amg
I bought a 2012 cls63 amg from the auction, the fan is running whenever I start the car, and it’s driving me crazy, the car does have k&n filters. I don’t know if the car is turned, but I don’t think so Do you think it’s the MAF ? I don’t have CEL , and the car is running well. Thanks for your help in advance
Old Oct 8, 2017 | 06:41 PM
JDMAP1's Avatar
it turned out that it was my tune that was causing the fan running constantly, it’s now been resolved but I’d definitely do the above as TTMerc had mentioned, especially the K&N filters gumming up sensors.
Old Oct 9, 2017 | 02:02 AM
firasmp3's Avatar
2012 Cls63 amg
I checked my fan on my friend’s car and it worked fine so it’s not the fan. Do you know where is the mass airflow sensor located? Any pictures? And agine I don’t CEL, thsnks
