C218 CLS63, 2011 - 2019
Lowering module
Old Jan 5, 2019 | 05:01 PM
Ericv13's Avatar
2013 C250
Lowering module
​​​​​Has anyone tried this or any other lowering module for a 2012 CLS sedan or similar? Are they any good ? Any issues ?
Old Jan 7, 2019 | 03:49 PM
fastback174's Avatar
2014 CLS AMG 2017 GLS 450
Have a '14 CLS 63 AMG. Would this module work? Thought only had airmatic in the
rear....not front as well.
Steve
Old May 6, 2019 | 10:38 PM
JDMAP1's Avatar
W222 S550, W218 CLS63, W166 ML550, Titan, Sentra
This will only work on vehicle with the "raise" button. Will NOT work with AMG CLS.
Old Aug 29, 2019 | 09:46 AM
Dmitry Gebber's Avatar
Mercedes-Benz
It works well with my MB s560 w222. But as for me I want to go much lower )) Max lowering level is -70mm from factory settings and the seller told me that go lower isn't safely for suspension.
Old Oct 23, 2019 | 05:54 PM
Mercedes-Benz
Originally Posted by Egor63s
As i understood you want to lower your S class more than for -70 mm ? Is it possible ? and I believe you need make an alignment ?
-70mm max lowering level
i thinks it's enough for the most drivers
you could see an example of -70mm lowering on this forum
Old Oct 23, 2019 | 06:16 PM
JDMAP1's Avatar
You will definitely need an alignment and rear camber kit, trust me I know. I lowered mine 2" (-50 mm ish) and my rear set of tires last 10K miles.
Old Oct 27, 2019 | 11:42 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Certainly will as there is only front and rear Toe "directional" adjustment OEM and we saw the need therefore to re-establish both front Camber and Caster. Rear Camber (and extra Toe) so can return vehicle to factory alignment specs!
Allowing once again to "adjust tire contact angles" correctly resolving costly, premature edge tire wear and ending the frustration of constantly changing tire brands or ongoing trips to dealers or alignment shops.
Catering for other than showroom height conditions.
Day to day commuting encountering high cambered roads, altered height through load carrying or lowering. Fitting wide profile tires / wheels, worn bushings or simply curb knock damage (kits also replace the highest wearing at the same time)
Single wrench precisely adjustable. Accurately (under load) direct on alignment rack
ALL MODEL W222
Front (Camber & Caster) #502816 K $480
Rear Camber and (extra Toe) #502526 $480
W218 CLS 250-550
Front (Camber & Caster) #502916 K $480
Rear Camber and (extra Toe) #502226 $480
W218 CLS 63, 65 AMG
Front (Camber & Caster) #503116 K $480
Delivery $30 (F/R $50)
PayPal, Visa or M/Card
Old Nov 5, 2019 | 11:25 AM
Ron Blc's Avatar
Mercedes-Benz
lol
Old Nov 20, 2019 | 01:54 PM
Ron Blc's Avatar
Mercedes-Benz
hi from Malaysia !!!
drive with
Amazon Amazon
lowering module!
MAX lowered on the pic! that's what you need for this car
Old Nov 24, 2019 | 06:09 AM
Erika Costa's Avatar
Mercedes-Benz CLS53
low mode is the best for cls w218!
lowered by Amz module
Old Dec 16, 2019 | 05:13 PM
Brad Diaz's Avatar
Mercedes-Benz GLC63
drive with Amazon lowering module!
​​​​​​​Is it comfortable to ride on this height?
Old Dec 16, 2019 | 07:15 PM
JDMAP1's Avatar
somewhat decent but you gonna be buying tires every 10K miles
Old Dec 16, 2019 | 07:19 PM
JDMAP1's Avatar
lol
but the car looks bad AF. Barely tucks, slammed big body.......nothin looks better than that
Old Feb 23, 2020 | 04:03 PM
`Steve Yanicks's Avatar
2017 GLE43
Also used lowering module in "low" mode
Old Mar 9, 2020 | 06:38 PM
M1RAG3's Avatar
CLS550 AMG Pkg.
Unfortunately CLS63 have not full Airmatic, so module will not work
agreed
only works on CLS550
Old Jul 17, 2020 | 02:20 AM
PekkaH's Avatar
2015 CLS550 Shooting brake 4-matic
Hi!
If you find a good mechanic, he can lower your Airmatic by Mercedes diagnostic tool "Star". No other stuff needed. My car is lowered like that. Rides nice low now.
Old Jul 21, 2020 | 12:13 PM
PekkaH's Avatar
For me personally it was the best choice to lower with Star. Mechanic didn't want any money with that lowering. CLS550 has that sport and comfort mode and also you can raise the car very high if needed as you know. I don't need to "play" with any different lowering highs that often. Maybe some others like. That is plenty enough for me.
Theres some function in AMG CLS63 that lower the car when speed comes about 170km/h. So maybe its not a good idea to lower the AMG with Star. I don't remember for sure.
