CF rear diffuser.
Here are a couple photos of the AF-1 style.
I ended up paying extra to have it shipped overnight
The biggest difference between the two pieces is how "in your face" the diffusers are. The RT-style one sticks out and up quite a bit. It is pretty dang aggressive. The AF-1 diffuser is much more subdued and tucked underneath while still giving a little bit of a sporty look with the diffuser ribs. Because the RT diffuser has a sweeping upwards shape to it it actually makes the entire rear of the car appear to be higher than it is due to the way your eyes follow the lines. The AF-1 diffuser appears to be lower than the RT style, but in all actuality, the RT is lower to the ground because of the lower edges of the ribs. As far as functionality, I would assume the RT is slightly more functional because the ribs extend significantly further forward under the car and also higher up on the back of the car giving a smoother transition for the airflow as a diffuser is designed to do. I doubt either of them has a very significant impact overall all as compared to a diffuser specifically built for aero function over form.
I attached a couple of pics of when I was swapping the pieces below. You can see in a couple of pics how bad the gap on the passenger side corner was before the clamp and after. Also, I now have an RT-style diffuser for sale if someone wants it. I'd sand it down and paint it flat black since the finish is shot. Other than that it's in great shape and will mount right up to your ride in less than ten minutes. I'm thinking $100 and you pay to ship.
12CLS63, please let us see the photos when you complete. I know the AF-1 has 3 years warranty. So you said the RW diffuser has started to fade color already? I'm just wondering how long has it been.
Going to put the OEM one back on until I figure out an alternative if another one at all. Also going to remove the front lip because it would just look dumb to only have a front lip and no diffuser. The front lip is fairly beaten as well........now the question is do I leave the mirror shells on without the rest of the exterior CF?? Decisions.
Also a picture of the AF-1 from further out and with the car not fresh off winter roads. Looks exactly how I want it to, but not nearly as easy to install as the RT-style one.
