Fitting 17" Wheels in the Rear
I removed the rear brake weights and tried a 17x9 +35 offset Enkei RPF1 and it would still would not clear the caliper.
Do I need a wider wheel? Different offset? Or do I need to shave/grind on the caliper?
Any information is greatly appreciated!
If the barrel of the wheel is what's rubbing the caliper then you'd need a 18" wheel.
I wish they made the RPF1s in the specs I'd want to fit the W212.
