C218 CLS63, 2011 - 2019
Cls550 eror code and hybrid turbo upgrade
Old Nov 22, 2024 | 04:39 PM
turhan's Avatar
Hello, good day, I wonder if anyone has encountered these codes before and I want to make the turbos of my vehicle hybrid turbo, has anyone tried or upgraded the turbo before? I would appreciate it if you share your information with me.
eror code p059700- p167085
Old Nov 24, 2024 | 05:03 AM
outlaw50's Avatar
Cls63 2013
Is the car tuned?
Is it a known hybrid or custom made?
Old Nov 24, 2024 | 05:06 AM
turhan's Avatar
Originally Posted by outlaw50
Is the car tuned?
There are stock turbos on the vehicle, I'm waiting for hybrids, these codes are stock turbo error
Old Nov 24, 2024 | 06:36 AM
trigital's Avatar
W213 All-terrain
The question was about if the engine software is manipulated or is stock. If is stock, a real diagnose is necessary before any tuning as the torque converter can be stiffed.
Old Nov 24, 2024 | 06:41 AM
turhan's Avatar
ohhhh my car stage2
Old Nov 24, 2024 | 06:51 AM
trigital's Avatar
W213 All-terrain
ohhhh my car stage2
Then you can try to change your tuner or to flash stock software if you want to make a proper diag.
Most of the tuners use "delete fault codes" from engine map fault code data base to hide the wrongdoings.
Old Nov 24, 2024 | 07:01 AM
turhan's Avatar
Do you have a CLS model vehicle?
If you have a vehicle with software, what is your 0-100 time?
Can you send me a video of the right turbo of your car?
And I have a lot question
Old Mar 20, 2025 | 03:19 PM
Planethill's Avatar
2018 GLC300 4Matic, 2008 ML350 4Matic
<Sorry-wrong thread>
Old Mar 20, 2025 | 03:43 PM
turhan's Avatar
[QUOTE=Planethill;9130382]OP ile ilgili olarak, bu yılın başlangıç ​​dönemlerinde. Turbonuz büyük ihtimalle iyidir. Alt-boost kodu, arızalı bir atık kapısı aktivatöründen katılıyor. Sorun şu ki Mercedes bunu EPC'de ayrı bir parça olarak göstermiyor, bunun yerine birkaç bin alanda yeni bir turbo ile birlikte geliyor! Amazon'da 25 adet bir parça ve otomatik olarak değiştirme çok kolay, yukarıda yayınlanan videoyu izleyebilirsiniz, 30 dakikadan kısa sürede yapabilirsiniz.[/QUOTE
]Bu videoyu bana gönderme şansınız var mı
