CLS W219 facelift LED Tail lights modules
Old Oct 5, 2016 | 02:05 AM
  #251
TheFrenchy's Avatar
Hello,
Yes i do
You've got PM.
Old Oct 6, 2016 | 06:14 AM
  #252
JBS1971's Avatar
CLS55 AMG
Hi Frenchy, I am interested in your modules. Please put me on the list.
Thanks!
Old Oct 6, 2016 | 05:36 PM
  #253
TheFrenchy's Avatar
Hello,
thank you for your interest, you've got PM
Old Oct 9, 2016 | 12:43 AM
  #254
CLS55 savage's Avatar
2006 CLS 55
Hello Frenchy, I would be interested in your module as well. PM sent to ya!
Thanks GM
Old Oct 9, 2016 | 02:08 PM
  #255
Andy27168's Avatar
Mercedes CLS55 AMG
Hi Frenchy.
Payment made as instructed.
Many Thanks, will look forward to fitting them,
Old Oct 10, 2016 | 06:21 PM
  #256
TheFrenchy's Avatar
Hello,
For the next orders, could you please add your Nickname to your paypal payement ?
Regards,
Frenchy
Old Oct 10, 2016 | 06:30 PM
  #257
2006 CLS 55
Sorry Frenchy, payment sent
Originally Posted by TheFrenchy
Hello,
Regards,
Frenchy
Old Oct 14, 2016 | 04:14 AM
  #258
CLS78's Avatar
CLS 55 AMG
Hello,
here is the DIY on how to remove the plastic housing in the trunk, and side carpets to access the 5 bolts of each Tail Lights :
You'll need :
- A little Flat Screwdriver
- a rubber lever
- L shape Spanner of 8 mm & 10 mm
- Torx #15
First you have to remove to small 4 plastic clips that retains the Plastic cover in the trunk :
Using one or 2 little flat screwdrivers, pull up the clip, and finish to extract it using a strong rubber lever to prevent any scratches on the cover.
When it's completely pulled, remove it.
When the 4 clips are removed, then you can pull out the cover :
Then, you'll have to unscrew with the torx#15, the small brackets for the trunk net on both sides, left and right.
After the brackets, you'lle have to remove 2 small clips on Top of each side carpets :
Now you can pull the carpets and make some enough place to access the bolts of the Tail lights.
Leave the small finition part over the rubber, you'll have to place it back at the end.
On the Left side, you should see this :
This big grey box is the central locking compressor, that why it's in foam rubber housing to isolate from the noise.
Unclip the OEM connector on the Back of the Tail light :
Just pull up this box, the bracket behind will loose and gives you more access to the side bolt of the tail light.
mate...i see that you have succeeded in replacing your CLS Tail Lights....The step-by-steps pictorial guide that you posted here are simply amazing & very useful for me...I'm familiar with all the steps but up to until replacing the original bulbs...You went on to replaced the whole tail light pieces...but i actually wants to replace the 'burned' original 'Reverse Light Bulb' ...I managed to take everything out like you did...but when i came to dismantling the defected light bulb, i failed to replace it....i just didn't know whether i just have to pull it out...or twist it out..or turn it around anti-clockwise?....i did try all of it..but just couldn't get it out.....So, i'm asking for your favour...if you could teach me how to pull the reverse light bulb off so i can replace it....If possible, a pictorial guide like above or whatever ways you can help me....I will trully appreciates it....thanks man!
Old Oct 14, 2016 | 07:38 AM
  #259
KILLERHERTZ's Avatar
2013 SL63 AMG
You turn it 90 degrees and pull out...
Old Oct 14, 2016 | 08:34 AM
  #260
CLS78's Avatar
CLS 55 AMG
thanks mate!..i will try it...
Old Oct 17, 2016 | 08:52 AM
  #261
mlakhlani's Avatar
C219 2008 CLS 320CDI
Hi Frenchy, could you put me on the list for your next batch please. I've sent you a PM, could you kindly advise on the cost as well please.
Old Oct 26, 2016 | 08:14 AM
  #262
zdenek CLS's Avatar
CLS 500 , w212 350 CGI
Hello TheFrenchy
How much does your play and play modul of light on?
You can send him to the Czech Republic?
Thank you
zdenek@nenadal.cz
Old Nov 15, 2016 | 12:18 AM
  #263
ksarpong's Avatar
CL555 ///AMG
CLS55
Figured I'd share some pictures of this W219. Somehow valet managed to loose this car a couple of weeks ago. Needless to say not in the best of moods but *ish happens.
Independent Kompressor cooling bypass... very necessary addition
Should any forum members randomly run across it, you know what to do!
Old Nov 15, 2016 | 11:55 AM
  #264
FunkTron's Avatar
2006 CLS55
that's crazy.
where do you live? (no location under your user name)
Old Nov 15, 2016 | 04:47 PM
  #265
ksarpong's Avatar
CL555 ///AMG
@FunkTron this happened in Atlanta in a development called Atlantic Station.
Old Nov 16, 2016 | 04:32 AM
  #266
Ali Ameen's Avatar
S320W220
Hi!
i owned a mercedez benz w220 s320 model. i have replaced the solenoid valve and compressor (brand new) almost 8 months ago. since last days i have noticed the car is sagging from the rear overnight and sometimes it is not sagging at all. I am sure there is a a problem with the airmatic component. But the question is if the leak is developed in the rear shock due to which the car is sagging then why the car is not sagging at all when i park the car on vehicle raise mode.
its making me very confused now which component to replace, wheather i needs to replace the valve block once again or both the rear struts.
Car is not sagging at all at vehicle rise mode.
Please help out!!!
Old Dec 1, 2016 | 01:44 PM
  #267
///Andrei's Avatar
CLS55 AMG, G63 AMG
Pm me please i am interested
Old Dec 1, 2016 | 01:46 PM
  #268
///Andrei's Avatar
CLS55 AMG, G63 AMG
My heart hurts for you bro. That is the GOD of all w219 with the right set up... What type of rear diffuser is that tho??? I have the same but 3 fin.... how did you mount that so flushed? did you have to cut the bottom bumper or is that diff paper thin? Wow.
Old Dec 27, 2016 | 12:27 AM
  #269
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hi Frenchy,
I would like to purchase the module
Merci Bien!
-Brandon
Old Feb 17, 2017 | 03:04 AM
  #270
Austins73's Avatar
2007 Cls 550
Hey I'm interested in a pair of the cls modules
Please and thank you
Old Feb 20, 2017 | 10:48 PM
  #271
516mbtek's Avatar
'06 CLS55 P030
Hi Frenchy
Interested in the LED modules if there is still a list please put me on it! Best Regards, Tim
Old Feb 21, 2017 | 08:16 PM
  #272
Seanbro1's Avatar
2008 W219 CLS63 AMG
Hello Frenchy
I'm interested in getting the facelift modules
Please advice
Sean
Old Feb 26, 2017 | 11:29 AM
  #273
Gobind's Avatar
Mercedes CLS 320 CDI
Hi Frenchy,
Im very interested in the CLS Facelift modules.
Can you tell me if you still sell them?
And the price?
Thanks.
Ive got the tail facelift laps but can not fit them.
Old Feb 26, 2017 | 11:34 AM
  #274
Gobind's Avatar
Please can you send me information ?
Thank you. Im desperate.
Old Feb 27, 2017 | 04:45 PM
  #275
Gobind's Avatar
Hi Frenchy, about the modules, this is my mail:
gobind@gysecan.es
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
