P030 Package Front 390mm Rotors
Old Jul 8, 2014 | 04:51 PM
Bud Wilkinson's Avatar
2007 Mercedes Benz CLS63 AMG
Originally Posted by RacingBrake
OEM two piece rotors are typically fastened together with McLaren hardware, which in our experience was facilitated for mass production (easier to machine U-slots in Aluminum hat than oblong holes in the iron discs), and is not as effective as our simple 2-pc device, below picture illustrates the actual movement of disc during expansion and contraction in heat cycles:
For the variety of fastening hardware, please refer to our web page here:
http://www.racingbrake.com/Rotor-Fas...are-s/6999.htm
Racing Brake,
I love your hat/open slot/centerline mount rotor design. If funds were unlimited I would definitely have gone this route. I appreciate all the links to parts that didn't come up in my initial searches as well.
As I stated however in my OP I was looking for a more economical package that gave the same or better performance than the stock units while retaining the AMG calipers.
I think in my case that goal was achieved.
After running the Bosch Quiet Cast pads for several miles now I think they are at least equal in initial bite and O/A performance to the unknown pads that came off the car if not a bit better. The removed pads were still approx. 45 - 50% remaining but the rotors were 1.5mm under min thickness spec so they had to go.
Old Jul 8, 2014 | 05:03 PM
TWF63's Avatar
07 cls63 amg, 09 R1
Originally Posted by Bud Wilkinson
TWF63,
No part number was made by Coleman as far as I know.
If you call the numbers in post 8 and talk to Lary or Troy they will give you the email address and you should be able to email the same brake rotor setup, solid mount sheet that I attached if you have a 2007 CLS63 or compatable P030 equiped car with 390mm two piece rotors that takes MB Part # 230-421-12-12.
Please understand that I have no idea which cars use that same part #. You will have to do the research but I believe 2006 - 2010 CLS63 390mm rotors are that part number. If you are not positive PLEASE measure your rotors.
Bud, we have same car.
Yea, I printed out your order form, thanks. This way I don't need to take my rotors off and wait. I will order set and once they come I will get to work. I will take measurements and pictures for hardware and post it here. Maybe we can find them which would be good for people that want to take same route in future.
Old Aug 16, 2014 | 11:28 PM
TWF63's Avatar
07 cls63 amg, 09 R1
My rotors came in today, 10 days after order
I was able to order over the phone thanks to Bud's previous order.
I need to order pads and than find free weekend to change them.
Thanks Bud.
Old Aug 18, 2014 | 08:24 PM
TWF63,
I hope your experience with the Colman rotors is as good as mine has been. I am several hundred miles into them and even with the very inexpensive Bosch Quiet Cast #1320 pads and these rotors, the AMG braking is Phenomenal.
Old Sep 30, 2014 | 09:37 PM
Hey all,
I have put about 1500 miles on the rotors and can report no troubles whatsoever. I did get a call from Coleman saying that they didn't want to just make rotors on my order name without my permission to do so. I am sending them an email so they will have that permission.
However your best bet would probably be to download their form here http://www.colemanracing.com/Assets/...rake_Rotor.pdf
Then if you don't want to take your own measurements you can copy mine from the form I attached in post #8 of this thread. That would work too. Having said that please read my disclaimer below.
PLEASE UNDERSTAND THAT I HAVE A 2007 CLS63 AMG WITH THE P30 PACKAGE 390mm FRONT ROTORS AND THESE WERE MY MEASUREMENTS. THE RESULTING CUSTOM COLEMAN ROTORS FIT MY CAR LIKE A GLOVE AND MAY FIT OTHER YEARS. HOWEVER I TAKE NO RESPONSIBILITY FOR THE FITMENT TO YOUR CAR EVEN IF IT IS A 2007 CLS63 AMG AND ENCOURAGE YOU TO AT LEAST REMOVE ONE ROTOR AND CONFIRM THESE DIMENSIONS FOR YOUR APPLICATION ON THE OFF CHANCE THAT SOMEWHERE IN ITS LIFE SOMEONE CHANGED THINGS FROM STOCK P30 PACKAGE ON YOUR CAR.
Old Sep 30, 2014 | 10:07 PM
TWF63's Avatar
07 cls63 amg, 09 R1
Thanks Bud.
I sent another guy there and told him to use my name for order but I guess it all goes back to you
I bought original MB pads but did not have time yet to install rotors/pads.
Old Oct 1, 2014 | 03:44 PM
  #32
Originally Posted by TWF63
Thanks Bud.
Would love to hear how your install went. I used red Loctite on my bolt/nut threads if I didn't say so before. Would have been fine without but I had it and a little extra lock won't hurt anything.
Old Sep 22, 2016 | 07:13 AM
  #33
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Here's some info that might be helpful.
Old Feb 23, 2018 | 03:54 AM
  #34
ap10046's Avatar
CLS500 M113
Are the caliper mounting brackets different from a regular 55?
Old thread, I know...but am doing my research on P30 rotors on a non-P30 car
Old Feb 25, 2018 | 11:23 PM
  #35
cm60k's Avatar
My friend made nice (390mm) Rotor adapter for my cousin 06 E55..
Old Feb 26, 2018 | 04:51 AM
  #36
ap10046's Avatar
CLS500 M113
Zayed...You are THE man!!!
