Need some help with 20" tire sizes
Old Jul 15, 2014 | 02:54 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I'm going to buy some 20" wheels this week, and I need to know what tires fit under the ball joint in front. What are you guys squeezing in there?
Russ
Old Jul 15, 2014 | 03:37 PM
I'd like to run Michelin pilot sport A/S 3 255-35-20 front
285-30-20 rear
Old Jul 15, 2014 | 06:51 PM
Rafiki's Avatar
2016 AMG GTS
its gonna rub, i ran that on my 20s first,255/35/20, kept rubbing, you will have to do 255/30/20front and 285/25/20 rear, my set up is slightly different now, i have 245/35/20 from and 305/30/20 in the rear
Old Jul 15, 2014 | 07:12 PM
Highend's Avatar
C219 CLS / W220 † / W211† / W210 E55 † / W210 Brabus † / Hamann 540i † /
I have 20" Apex Wheels for sale with tires
Front 245x30x20 Hankook Ventus V12 Tires 2 Months old
Rear 295or305x25x20 Need to be replaced with whatever size you like
https://mbworld.org/forums/wheels-ti...rt-wheels.html
Old Jul 15, 2014 | 08:10 PM
Manofsteelpt's Avatar
Veteran: Army
S63
How do those 305/30's fit back there? Have any pix? That's my next size I wanna goto. I currently have 295/30/20 with no issues.
I run the same 245/35 up front, but it def SEEMS like enough room for the 255/35. Did they rub the fender or hit the ball joint screw?
I am at stock height...
Old Jul 15, 2014 | 09:10 PM
Thanks for the info guys!
Were did they rub?
I've kinda got my heart set on a different style, but how much for the apex 20's
Old Jul 15, 2014 | 10:11 PM
Rafiki's Avatar
2016 AMG GTS
It Fits perfect will try and get a pic in the morning, the 255/35 was rubbing on the upper ball joint, I am at stock height, , it was also ripping the tire , good thing I had insurance with Discount Tires so I swapped em out for the 245/35 , helps a little with bumps
Old Jul 16, 2014 | 12:58 AM
Jawzey's Avatar
CLS55 AMG
Interested in the same setup as OP.
Want to run 245/35-20 up front, with 305/30-20 in the rear on Michelin PSS. Can this be accomplished without any rubbing issues? My primary concern is the fitment of what would be the rear tires.
Old Jul 16, 2014 | 06:22 AM
If it's just at the ball joint nut, I think I can fix that. Learned a few tricks working on airplanes.
Old Jul 16, 2014 | 06:34 AM
s.
That looks like a sweet setup, 26.8 diameter in the front. Close but no kissing.
Old Jul 16, 2014 | 06:50 AM
Rafiki's Avatar
2016 AMG GTS
Am running the exact setup too, plus I need the extra meat. I live in Chicago, worst roads IMO after NY LOL
Old Jul 16, 2014 | 06:52 AM
Rafiki's Avatar
2016 AMG GTS
Depends on d rear tires but I have Toyo Proxies for my rears on 20x10.5 rims and it fits like a glove , plus no rubbing and doesn't stick out
Old Jul 16, 2014 | 08:28 AM
Veteran: Army
S63
I'm running PSS 245/35, 295/30/20. I see no reason I can't bump to the 305, looks like I have plenty of room.
Old Jul 16, 2014 | 05:04 PM
Highend's Avatar
Were did they rub?
No worries, I understand that. $900
I'm not trying to make anything on them honestly, just need to sell since I've got to go back to stock. They cost $1600-1900 new depending on tires from almost any vendor. I originally ran 305 in the rear with them, no rubbing issues on a lowered C219.
Old Jul 17, 2014 | 02:32 AM
dafoodangel's Avatar
CLS55 AMG, E63s AMG, NSX, Atlas Cross Sport
im currently running a 255/35/20 front and 285/30/20 with no rubbing issues on the ball joint. only slight rubbing on full tilt. im on semi aggressive drop
Old Jul 17, 2014 | 02:52 AM
Need4Speed's Avatar
Former Vendor of MBWorld
2018 C63S
I would recommend the following
255/30/20
295/25/20
We do a number of CLS vehicles on 20" wheels and this works everytime !
I have seen up to a 305 be used on the rear no issues
Old Jul 17, 2014 | 05:06 AM
Thanks. now that that is settled, The wheels I want are offset 10mm in and I really don't want to run spacers.
The ones I want are 2010 CLS63 replicas. 5 spoke but each spoke has 3 legs. They suit the car and look good without saying "look at me!"
Old Jul 17, 2014 | 10:03 AM
06cls55amg's Avatar
06cls
do not run 255 with out proper offset wheel, spacers will cause the steering to shimmy.
i went through hell with 255s and still looking for a 10mm spacer that wont shimmy on my cls
Old Jul 17, 2014 | 07:08 PM
Thanks, it was your posts that gave me an aversion to spacers in the first place.
I'm about ready to give up and just buy tires. I'm running maypops with 33000 miles on them.
Old Jul 17, 2014 | 07:24 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I have 255/35/20 on the front of both my CLS55 and my E55. Both are Toyo Proxes and I've driven almost a combined 30,000 miles on them with no rubbing except the plastic inner wheelwell liner in the front at full steering lock.
Old Jul 17, 2014 | 08:07 PM
That's good mileage for a tire with 280 UTQG. You must be doing something right.
Old Jul 18, 2014 | 03:21 AM
Combined between the two cars..
Old Jul 18, 2014 | 04:35 AM
I got that, still 15k and counting. I only got 10k out of my first 4 sets, then I switched to DWS with a 540 rating and made some changes to the front end.
Old Jul 20, 2014 | 05:48 AM
BlackB-Wald's Avatar
E350 4matic, Porsche Cayenne S
Hi guys,
I need help. So, I have Rohana wheels RC10. Front: 20x10 and Rear: 20x11.
What set up of wheel would you recommend?
I always have tire wear. I changed my tires 2 times in 3 or 4 months.
I also install K-Mac bush kit for my rear.
Old Jul 20, 2014 | 07:36 AM
Flip your tires when they are half gone, and use way less toe than factory spec once you get some of the flex out of your rubber bushings. (K-mac or even updated new for the front thrust arms) I'm running 15 thousandths total toe in the front at the edge of the rim, and just a shade more in the back. These cars are set up for soft bushings at 186mph and 155mph. They scuff the tires right off at 60. The back is tricky because it toes out when you punch it and becomes a handful with too little toe. Lots of flex. I'm hoping K-mac will reduce it some.
