Those without a spare tire, we have fix-a-flat and a jack
Old Jun 3, 2005 | 02:56 AM
bnz616's Avatar
2012 GL550
Those without a spare that have gotten tire troubles on the road, have you ever used the fix-a-flat and jack that came with the car? I noticed that my can/bottle of fix-a-flat has been used, probably by the previous owner. How well does that stuff work? Should I bother replacing that bottle with a new one? Where can I get a bottle like that, or is the dealership the only place.
Old Jun 4, 2005 | 09:33 AM
Narcissus's Avatar
2001 C240 Tectite
It works fine for small punctures... Anything bigger than say 5-7 mm and you'll have to call good ol' roadside assistance
The can should be good for 2-3 applications if used accordingly
Old Jun 5, 2005 | 12:13 AM
bnz616's Avatar
2012 GL550
Hmm..okie. I think I will check to see if theres anything good left in the can. Its been sitting open in the trunk. I see the bag it was probably originally in and the snorkel, but the can is open, no lid or anything covering it. If not, I guess its a good idea to pick up a replacement for those quick patches if I'm on the road.
Old Jun 5, 2005 | 11:04 AM
Narcissus's Avatar
2001 C240 Tectite
Yes it would be a good idea especially since a can needs to be replaced every 3-4 years, just don'T buy the one at the dealer, you can find the same thing at any auto store for 1/2 or 1/3 of the price
Old Jun 5, 2005 | 04:19 PM
bnz616's Avatar
2012 GL550
Ahh ok. Its that yellow can called fix a flat or something right.
Old Jan 10, 2006 | 02:09 AM
pshek's Avatar
2003 C-Class Sportcoupe
Unhappy
Can somebody please tell me if it's okay to use fix a flat ie tire sealer on low profile ZR rated tires. I have Nitto NT555 tires on my 19" SSR GT3 and I have a slow air leak on my right rear tire. Is it safe to use on this type of tire and wheel combination? I'm going to take off the wheel and inspect it before I fill it with the compound though.
Old Jan 10, 2006 | 03:08 AM
ClayJ's Avatar
ON PROBATION
Absolutely. Just make sure that you get at least 10 minutes of highway or freeway (high speed) driving in right after you put the contents of the can into your tire - this ensures that the tires get up to temp and spread all of that stuff around evenly in there, and so that the leak is fixed. It may be true that you can just drive around town at 35-45mph or so -- but I always like to hit a freeway or highway.....
Old Jan 10, 2006 | 03:38 AM
Dead Ringer's Avatar
02 C32R
just be prepared to take your car to a good detailer, since you are going to need them to clean all that goo thats plastered all over the side of you car when it comes out of the hole you are sealing ....... yes this has happened to me if you cant tell, was in a different car though but it did work and sealed the tire
Old Jan 10, 2006 | 09:05 AM
genechien's Avatar
'05 C55 AMG
also, most punctures to the sidewall of the tire can't be fixed with a patch and you'll need to get a whole new tire.
Old Jan 10, 2006 | 11:51 AM
pshek's Avatar
thanks.
