(Pic) HR Springs, Rear looks too low? Spring Pads? and Front Strut Tower?
Old Aug 17, 2005 | 08:42 PM
2002c32's Avatar
I just had my HR Springs installed. I have a couple of questions on both the front and rear.
Rear:
1. Looks too low.
2. Can I stack the rear spring pads until I get the correct height
3. Have 4 dot rear pads on order will this help? Not sure of rear size now? (Was it a 2 dot)
Front:
1. One of the rubber pads looks upside down, can anyone confirm this.
2. Please post pics of both your left and right front strut towers.
Attached Thumbnails (Pic) HR Springs, Rear looks too low? Spring Pads? and Front Strut Tower?-2002c32.jpg   (Pic) HR Springs, Rear looks too low? Spring Pads? and Front Strut Tower?-left-tower.jpg   (Pic) HR Springs, Rear looks too low? Spring Pads? and Front Strut Tower?-right-tower.jpg
Old Aug 17, 2005 | 10:17 PM
xxbenzc230kxx's Avatar
is not yet completed
yeh the stock rear pads are 2dot... a 4 dot will raise it up.. enough to be even with the front gap
Old Aug 17, 2005 | 10:40 PM
smgC32's Avatar
Most aftermarket springs produce a 1.5" drop in the front, from 15" to 13.5", and a .50 - 1.0" drop in the rear depending on spring pads, from 13.5" to 12.5" - 13.0" as measured from the center of the hub to the fender lip.
Your car looks great. The front seems to be a little higher than the standards quoted above and the rear seems a little lower. I would guess the front is 13.75" and the rear 12.25". My Carlsson's are currently set at 13.25" front and 12.25" rear. A thicker rear pad will give you some more height if you think you need it. Remember that when the car is loaded in the rear it will drop even more.
What wheels are those?!
Old Aug 18, 2005 | 12:36 AM
psk145's Avatar
2006 E55
mine looks like that too, If you look at the stock setup, the rear is tucked in more than the front
IwantA124's Avatar
It won't even out the height with the front, but it will raise the rear just above the tire. It will look real nice.
Old Aug 18, 2005 | 02:42 AM
BenzoAMGpower's Avatar
Cars and boats!
rear does not look too low, the front actually looks too high!!
Old Aug 18, 2005 | 06:51 AM
2002c32's Avatar
The wheels are from a slk55 amg.
Can you stack the pads until you get the correct height?
Old Aug 18, 2005 | 11:57 AM
glomar83's Avatar
05 c55
my rear tires rub sometimes under heavy cornering/ with weight in the back and hard acceleration. could i stack spring pads to raise rear of the car
Old Aug 19, 2005 | 01:05 AM
smgC32's Avatar
No. But you could buy adjustable perches.
