That Daam C55 Engine Noise!
Can't stand it. DOesn't sound like it should be coming from the hood of a Merc AMG. I'm talking about that whine after you start the car. Wheeeeennnggg. Hit the gas while car warms up--as you gas--the whine gets louder. Finally, it dies down a bit after the car is warm. But even after, when you accellerate a slight whine under the hood still follows you around. What is that damm noise. So many theories. Is something that annoying normal? Not sure if it's affecting performance of car. Help me understand, someone. Anyone else out there with this problem--if it is in fact a defect or a "problem. Suggestions on what to tell the dealer it is so I can get it fixed. That is if it should be fixed. TX
Originally Posted by skytop
It's the standard S/C clutch whine. Wait till you get older, your hearing gets weaker, you won't hear a thing.
Oh I'm just kiddin'
2014 C250 sport
he is talking about the C55.it's normal, I think it sounds cool though. My dad's ML55 does this, and so do the 4.3 and 5.0 liter's, and 55 kompressors,this particular sound has nothing to do with the S/C clutch.
So, the semi-unofficial name of your loud whine is ...
"The Dubai Option"
2025 AMG E 53 (on order); 2018 GLC300 4Matic; 2003 360 Modena
It's a C55 engine, no s/c. It's not the cooling fans - it is most prominent when the engine is cold, >8hrs off. I have the exact same noise, also have heard it in other C55s and CLK55s.
I have communication going with another owner from a different Benz sight - he is meeting with AMG technicians in Sept., I'll be at the AMG event in Joliet, IL on 9/18 and discuss with the tech then.
It is far from normal - I'm almost certain that it is the power steering pump. I'm working with Knauz to determine what exactly is causing the noise - but trying to avoid just throwing parts at it.
1 Post
C55AMG W203; 330i E90
NOT a problem. It is the sound of the radiator.
You will hear the car making this sound when under the direct sun light or when the car slow down. Normally this sound will not occur at first 5 minutes after a cold start. Most of the times, you slow down the car , the sound will come. It does not happen too often in cold weather.
Turn off the air cond , the sound will cease
I think every one here got this confirmed by the dealer, it is normal.
I recall some S500 I come across make the same sound, but may be
the sound proof of S class for 5 litre animal is better than a C-Class
I love this sound because it scares people :v
It is definitely NOT the sound of a radiator! A radiator is not capable of producing a mechanical noise. And how does direct sunlight or the car slowing down contribute to this noise?
This noise is most prominent immediately on a cold start and begins to diminish after about 30sec. The A/C has no effect - this post is not describing the cooling fan associated with running the A/C.
If anyone is familiar with the sound of a failing or starved power steering pump - this noise is almost identical.
05 C55, BMWX 3.0, Subaru Forester (Shaggin Wagon)
Guys:
Since these comments are all over the place, I would suggest that you open the hood stand over the engine and have someone else start the car. Listen and determine where the noise is coming from to be fully convinced.
The sound that I believe that you are hearing I have also heard at startup from my car. It sounds initially very load, almost grindy and then calms down about 15-30 seconds. The other sounds that have been articulated I have also heard such as the radiator fan blower kicking in.
I believe we have all heard these sounds and it always was my assumption that this was quite normal for the C55, just as I have engine noise from about 75mph and never had that in my 05 CLK500. I was told that you are supposed to hear the racing tuned engine as this is a is part of the "AMG experience".
I would personally like to hear more about this from you, what you find out and what you did to get to the bottom of it.
Originally Posted by kjb55
if anyone wants a .wav file of the sound - let me know - I'll email it to you.
a few...
well whatever the sound comes out to being, I can assure you it is completely normal. At least with my MB experience.
Coming from 2 SLs, an older S55 and two new S600s and an E55, I have heard this on all of them so as far as I know it is normal.
I think it might be a cold start cycle for the engine because it seems to last longer the longer the car has been sitting.
But that's just my .02
1 Post
I can't argue on this 'radiator' thing as I read this from another thread some months ago. But what golden sure is:
1. the sound comes most times when the car is slowing down or in slow motion. Not as you said , only 15 mins immediate after a cold start
2. some time , the sound gets triggered when you open your car window when cold air cond is on.
3. 16000km , 12 months - I have not heard one single sound/noise which differs from any kinds of sounds under the hood since the first day I receive my car key. ( I would say , this is by far perfect )
1. The noise has NOTHING to do with 'slowing down' or in 'slow motion'. Read the post - I never said anything about '15mins immediate after a cold start' but immediately after a car cold start and diminishing after 30sec!!
2. The noise has NOTHING to do with 'when you open your car window when cold air cond is on'.
And...
3. If you care to hear the noise - let me know your email - and I'll email you a sound clip.
W203 C240
dont know if this helps but the A/c on my car makes it have a slight higher pitched whine. Starting is a bit rough btw my mom's w211 e500 is smoother & i havent noticed the a/c whine on it.
is your a/c on when you start up, even on auto?
'07 E63; 05 C55 gone; '02 C32 gone;1996 SL320;1978 280CE Gone
kjb: I understand. My car does it too. The service mgr at dealer said it is normal, but never really explained what it is. Next time I'm in, I will ask for more info.
1 Post
Okay look - your car apparently doesn't exhibit the noise that myself and mwiseltier are trying to solve.
And...
And...
Send me a clip at
gemini@iohk.com
C32 AMG 2002, C 63 AMG 2009
Originally Posted by ricky.agrawal
LMAO like the target audience for the CL right?
Oh I'm just kiddin'
Oh I'm just kiddin'
Miami Bass, if your ears aren't bleeding, then it;s not loud enough
