Just purchased an '02 c32 AMG was wondering...
Old May 28, 2006 | 02:55 PM
herkjerk's Avatar
'02 C32 AMG, '69 BMW 2002, MC-130H
How I should go about clearing the PO's info from the car? Can I just disconnect the battery for a few minutes or...? Also if you have any other advice for a new owner I would appreciate any inputs.
Old May 28, 2006 | 03:18 PM
Scoop55's Avatar
'05 C55 AMG '15 Jeep SRT '11 G37S
Do you know of any mods that have been done to it already? Also, post some pics when you get a chance!
Old May 28, 2006 | 03:39 PM
herkjerk's Avatar
It's pretty much stock
It does have the flat front emblem and a rear spoiler, but other then that it's pretty much unmolested. Brilliant siver with black on black interior. I'll get pics when I take possession of the car on Tuesday. It was owned by the wife of a business exec, so it hasn't been flogged too much either and I think I got a pretty good deal on it (paid 22.5k). Looking forward to getting it in the driveway next to my '69 bmw I just restored for some pics
Old May 28, 2006 | 04:50 PM
Eurocharged Rick's Avatar
SPONSOR
i would not disconnect the battery, you have to resync alot of stuff when you do that and there is a module or something in the rear i remember reading about that goes bad on some cars....i would go through the process of reprogramming everything manually for your preference, then do the ecu reset that is found here...
https://mbworld.org/forums/c32-amg-c55-amg-w203/148135-makin-sure-c55-32-brothas-hooked-up-ecu-reset-smokes.html
Old May 29, 2006 | 04:22 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
congratz with the purchase.
Old May 30, 2006 | 12:30 AM
herkjerk's Avatar
Thanks!
Old May 30, 2006 | 06:48 PM
mk2tmr2's Avatar
C32
You can reset the options back to factory spec quite easily. Just consult the user manual if you can't figure it out.
Old May 30, 2006 | 09:23 PM
herkjerk's Avatar
yeah, I read that in the manual...
I was more interested in the car "unlearning" the PO's driving habits and starting from scratch, but it looks like I can just do the trick to reset the ECU and that should clear everything. Thanks.
Old May 31, 2006 | 12:31 AM
Bif powell's Avatar
2002 c32
Does not clear the tranny adaptation AFAIK.
Old May 31, 2006 | 07:48 AM
herkjerk's Avatar
Really?...
What will? Or is it not possible?
Old May 31, 2006 | 11:21 AM
Bif powell's Avatar
2002 c32
There is a procedure where you monitor engine conditions and drive around at certain speeds until the engine reaches x-degrees, then you drive slow for a while, etc...that's my understanding. Eventually it will just learn how you drive and 'forget' the old driver(? anyone chime in there).
