Glycol Test At Home??
Old Jun 12, 2006 | 08:48 PM
bViC's Avatar
2002 c32 /////amg
Anyone did their own glycol tests at home?? i found this kit online
http://www.bestlabdeals.com/ProductD...t1134&click=35
Old Jun 12, 2006 | 09:08 PM
C32AMG/02's Avatar
The test is free (dealer) if your car was produced before 09/2003. The production date is on the ID plate, drivers’ side door pillar
Old Jun 12, 2006 | 11:22 PM
bViC's Avatar
2002 c32 /////amg
does anyone know whre does the contamination takes place? where does it get into the transmission?
Old Jun 12, 2006 | 11:32 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
Yes. It leaks from radiator into transmission.
Old Jun 13, 2006 | 10:51 PM
bViC's Avatar
2002 c32 /////amg
i mean from which part (hose, seals etc.)
Old Jun 13, 2006 | 10:57 PM
DL_AMG's Avatar
You can do a search...
https://mbworld.org/forums/c32-amg-c55-amg-w203/134649-help-another-transmission-jerk-dealer.html
It's defected radiator (possible seals) cause it to leak.
Old Jun 14, 2006 | 04:19 PM
bnz616's Avatar
2012 GL550
Is this known to all dealers? If so, I wouldn't mind taking it in to have them run the test.
Thanks.
Old Jun 19, 2006 | 08:07 PM
C32AMG/02's Avatar
Thanks.
The glycol test is free only if the production date of the vehicle is up to 09/2003 and the radiator was made by Valeo. Bulletin # P-B-27.55/50, covers models 203, 209, and211.
When you call your service advisor tell them the transmission has a droning/buzzing noise/ harsh 2nd to 3rd shift at between 1200and 2500RPMs.
. All automatic transmission radiators have an internal transmission fluid inter cooler in the radiator, which cools the transmission fluid before it returns to the transmission. If this cooler fails coolant/glycol will mix with transmission fluid = transmission failure.
Old Jun 22, 2006 | 06:15 PM
amgme's Avatar
07 SL550; C32 (sold)
is it free if it's out of warranty? mine is out of warranty and requested this test. guess what? they are asking $600 for the test alone!!! + labor!!! is that right? $600 worth of chemicals? are the chemicals produced on mars?
Old Jun 22, 2006 | 06:46 PM
bViC's Avatar
2002 c32 /////amg
you can do it yourself at home, or you can call an independent transmission place, most of the bigger ones can do it for alot cheaper
Old Jun 22, 2006 | 07:01 PM
C32AMG/02's Avatar
Did you have a shifting problem and complain about it too your dealer when the car was under warranty, any documentation to support your claim, Paper work, invoices, you may have a very good case. If not I doubt they would cover the cost.
$600 + labor!!!
Old Jun 22, 2006 | 08:26 PM
Moxxon's Avatar
Flint Gray E63
Has anybody had this test done at Walnut Creek Mercedes? My C32 was built 3/03 and I am wondering if they will do this test for free or want to charge me some crazy amount of money. Transmission is fine right now, no jerking or buzzing, but I want to get the test done just in case and even if it's negative, I will eventually replace the radiator.
Old Jun 22, 2006 | 08:51 PM
amgme's Avatar
$600 + labor!!!
yes i have the shifting problem but went to another dealership for that. they never did fix it so i went somewhere else. i'm sure the previous dealership has the documentations. i also did mention to him that i complained about this problem when it was under warranty and ask if they can cover the cost. he said that even if i brought it to him under warranty b4 the tsb it would still cost me $$ to do the test since it's currently out of warranty. that's
Old Jun 23, 2006 | 12:18 AM
amgme's Avatar
i just might do it myself. just need to know how? has anyone done it here? and is their kit really $600 or was just bs'ing?
Old Jun 23, 2006 | 04:02 PM
bViC's Avatar
2002 c32 /////amg
you can get the kit for around $80, here the site. you get enought for 25 tests.
