No Power
Mercedes C32
No Power
Yo can someone help me out here. When I am on the freeway going about 80 i floor it and there is no power. But when i am at a light i gun it and the power is all there. Can some one help me with this major problem?
MBworld Guru
white and whiter
yup...
have the dealer run a electric current check on the pump. it's free if you still have the warranty. around $600 if you don't. check one of the threads on this. someone said the Ford Lightning uses the same I/C pump which cost 1/2 the price at Ford dealership.
C32 AMG Maserati Coupe GT
Originally Posted by Furious
Could also be the fuel pump. I had to have mine replaced. When I floored it, it felt like a 4 cylinder engine.
Mercedes C32
Yo
Thanks for all the input. My check engine light is not on so I dont know hopefully its just the ic pump and not a fuel pump. Thanks all
2003 C32
No, the check engine light will not come on. There will not be enough fuel pressure at times, so you will have temporary acceleration problems (ie no power). Eventually, the fuel pump will stop working and you won't be able to get your car started. At least in my case.
Mercedes C32
I hope its easy. I am not that good of a mechanic. lol. But I was reading up on 1fasts idea of the lighting pump. My only concern is adding the new connectors or splicing into the old ones. Electrical things makes me nervous
Originally Posted by ebp
Wait, so is this problem only related to the intercooler pump, or does the fuel pump need to be replaced too?
03 C32
Yo, I just got my C32 back from the dealer for the same problem, losing power at high speeds. They replaced my intercooler, b/c it was reading the intake air temperatures too high b/c the coolent pump wasn't working for the intercooler , or something. Anyways it was under warranty, and didn't cost me a dime. Now my car drives like a dream again
Mercedes C32
Well I just got my intercooler pump in yesterday. I got the one for the ford
I will let you know what happens. I am changing it out tonight. If you guys have any quick tips let me know.
Mercedes C32
WOW THE POWER IS BACK. What a difference. I change the intercooler pump out like everyone said and wow what a difference. I used the intructions that 1fast come up with and it takes no time to do. The only thing that took the longest was those damn mb clamps that they use for the hoses. I hate those things. But I took my old pump off replaced it with the ford one and bam kicking *** again. Thanks everyone for the responses and help...
glad you got it working again....
i'm a bit confused how to ensure to avoid any air bubbles in the system.
hey guys u think is it bs that fuel pump would burn the sam(rear cp). The mechanics told me that and they have to change the fuel pump which is back order form germany and sam for 2100 with everything(no warranty)
Mercedes C32
I did use the same coolant. its the mercedes benz coolant. I picked it up at my local mb dealership. cost me about 17 dollars. And all i did was just refill resevoir. Didnt have any problems with air bubbles.
