C32 @ 426hp & 593lb/t
Audi C7.5 S6
Also,
Take a look at the Whipple page for the new Mustang blower kit. At 10lbs/sqin, the HO IC version is putting out 475RWHP.
http://www.whipplesuperchargers.com/...sp?ProdID=1208
They mention,
"For boost levels over 16lbs, a race belt system will be required."
Instead of using a belt clutch, they use a vacuum bypass, which is a lot easier to implement at high power levels.
I have been to the whipple facility, it's pretty nice. They have an engine dyno & chassis dyno & machine shop. If one could get their attention, they could do some interesting setups for the Mercedes, but they are too busy, with the boats and trucks.
They mention,
#32
C32 K AMG 03/2002
#33
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
why do folks bandy around torque numbers without quoting the rpm??
there's a linear relationship between torque and hp.
who cares if a car makes 500 ft lbs torque at 2000 rpm? i'd like that in a tractor yes. give me ~300ft lbs flat between 3500 to 8500 rpm and i will be verry happy.
#34
2004 S/C M3 Vert, 2004 E55
Not too sure how to explain it I guess. But on my v6 accord I had a comptech s/c and it was a belt driven clutch type. An intercooler did not add hp and some actually lost. But an aftercooler allowed for 2psi extra boost and larger fuel injectors which brought whp from 300 to 350-370 #s varied in between. So i wasnt sure if we could do something similiar. Here are various pics the ones shown installed are not on my car but it is my kit that i recently sold.
#35
S600TT, R350
That is a very well done setup for Accord.
Awhile back I had started fabricating very similar top mounted water/air intercoolers for C32. However, other projects and lack of interest stopped the design.
#36
looks like a nice setup, but unfortunately an aftercooler setup will not work on our car...you could fab up a seperate intercooler reservoir and more efficient heat exchanger, which is what i am working on....
