radiator diy
1 Post
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
radiator diy
hi all,
does anyone have a radiator diy for the c32? if it's as easy as doing it in other cars (namely hondas, toyotas, audis) i'll do it myself and save $150 in labor.
you know, i do everything myself...but if that is all it cost to get it replaced, i would just pay it...
it is not hard, just time consuming, as it takes about 30 minutes just to drain the radiator itself, probably take you 2-3 hours not getting in a hurry...
but if you want to do it yourself...drain it, pull everything out of your way to clear the way to get it out, remove the fan, pull the hoses off, then pull the radiator...reverse for install...that is the simple version
