Oil Change
Alabaster White C230K Grey Int. and 2003 C32 pewter/charcoal gray
Oil Change
Ive search the forum and found a few articles on how to change your own oil. Is there anybody that can post picts where filter is located and how does it looks like? Thanks
Your screen name suggests you have a C230. If you're asking about the C32, the filter is right on top, in the front left of the the engine compartment (driver's side). It's a black, rounded cap. With the correct filter wrench, you undo the cap and pull out the whole structure. The filter sits on a plastic post -- you slide it down and off, and put the new filter in its place. Your filter will come with a few rubber gaskets that are to replace the gaskets on the post you pulled out. It can get messy.
Right on top of the engine. If it were a snake you would have been bitten!
There are pics and instructions on here, search a little better.
