My damn key is stuck in ignition!!
Old May 14, 2007 | 02:21 PM
boohooramblers's Avatar
Not an AMG :(
Y'all:
I'm sitting here stranded because the friggin' key is stuck in the ignition, wont start the car, and the key wont come out either!
Everything electrical seems to be fine. (e.g. power seats, dash, etc.). The key turns to the last position to the right but wont start the car.
When I turn the ignition all the way to the left, the key wont come out. I had spare batteries for the key at work so I changed them. No luck!
Anyone got any quick suggestions? I'd hate to leave the car with the key in it and get a ride home to get my other key!
Thanks!
Old May 14, 2007 | 02:30 PM
aecasasus's Avatar
'04 C230K SS
Might sound stupid but it's a starter...... Is the car Manual or Automatic? If it's automatic...make sure it's in Parking position.
Old May 14, 2007 | 02:38 PM
Not an AMG :(
Yep - it's in P - thanks for the quick response though!
Old May 14, 2007 | 02:46 PM
gkstar's Avatar
C32 AMG - in Pewter
I suspect the problem is that your car's CPU/controller does not recognize that the stick is in Park and as a result does not allow you to start the engine nor it allows you to pull the key out. Move you stick back and forth a few times, try in Neutral as well.
Old May 14, 2007 | 03:02 PM
Not an AMG :(
CHAMPION!!!
I moved the stick back and forth and on the 4th try there was a click and hey presto! That's pretty weird since the 'P' LED was lit up prior to shifting it
Thanks a lot gkstar!
Old May 14, 2007 | 03:04 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Originally Posted by boohooramblers
CHAMPION!!!
I moved the stick back and forth and on the 4 try there was a click and hey presto! That's pretty weird since the 'P' LED was lit up prior to shifting it
Were you on a hill?
Old May 14, 2007 | 03:07 PM
Not an AMG :(
Originally Posted by AMG-Jerry
Were you on a hill?
Nah - pretty even parking lot here at the VA. Why? - does an uneven parking surface do this sometimes?
Old May 14, 2007 | 03:09 PM
SPONSOR
C63S
Not that I know of. I was trying to think of why it wouldn't have gone into park.
