Amg C55 Staying At High Rpm While Driving?
Was up Guys. I am new to this form, i just picked up a new C55 AMG and i must say before i did that i got most of my info from this site and you guys really know what ur talking about, the car is AMAZING, i just parted with my supercharged G35 done by Stillen, which was alot of fun but moved on.
Well after driving the car i noticed that the RPMs stays at a high rate even not full throttling, when i mean high it stays at the 3000 3200 mark with a rar.
as well when i drive at a slow paste acceleration its changes gear at same peak.
does any one else experience the same thing is that normal?
your insight please.
Thanks. -blackroof
Thanks. -blackroof
08 M5, 06 X3, 05 C55
I just got a C55 a month ago as well and noticed something similar. It seems when you accelerate quickly and then let off the gas... the car tends to stay in the higher RPM range for a couple seconds before upshifting.
if you're accerlating slowly, it shouldn't be shifting so high all the time.
1 Post
C55 AMG, 135i, 911 GT3, GLE43 AMG
That is normal, especially if you've been driving fast (lots of throttle) in S mode. The transmission is adaptive and will automatically hold the gear and delay upshifts to keep the engine at higher rpm's so you can get instant power if you want to. However, if you drive more sedately, it will revert to a more relaxed shift mode and upshift at lower rpm's. Remember, you can always manually upshift or downshift with the gear lever or buttons on the back anytime you want if you want more control. If you want complete control, move into M mode.
In the city when I can't really go that fast, I usually keep my car in C mode, which gives a much more typical "benz" type of shift, smooth, and at lower rpm's to minimize the jerkiness.
Thanks. -blackroof
Thanks. -blackroof
it does the same to the non AMG w203s. when you step on it real fast and let go. it will auto downshift for you thinking that you need to speed up..but its too slow to auto shift up again.... so, your car is fine.
nice pick on the C55
Thanks guys . its good to know that I am not the only one feeling the same thing. i know the M- Mode is Manual the S Mode is Sport and the C is Cruse? is that correct..
I was looking to invest in the ECU upgrade for the C55, any recommendations. I called Powerchip, and had a respectful conversation with the project manager, and he sounds pretty sure and confident about the product. any one has the upgrade?
-blackroof.
-blackroof.
2006 C55/400HP HONDA S2000
TO BE EXACT C IS FOR COMFORT yes my c55 also does the same like someone said before its adaptive ........ and if you see this means your driving the car like you should !!!!!
Cobra/E55
-blackroof.
-blackroof.
Cobra/E55
