Replacing Bosch IC pump with Johnson C030
C32 AMG
Funny thing is that the original seller is probably wondering why the heck there is a run on pumps right now
2003 C-Class Sportcoupe
Originally Posted by rlee02135
has anyone actually received a pump from this seller yet?
MBworld Guru
white and whiter
I got mine from them in a few days. Came in a small plain white box with instructions, bracket, and the pump.
I don't know about you but I'm using the water pumps for my marine aquarium. Even though my oem Bosch pump isn't broken yet, I'll probably end up changing it to my CM30 or CM90. Maybe I'll use the Bosch automotive pump for a marine aquarium filtration system.
#36
Location: dayton ohio hopefully it will be some place warm and sunny when i finish med school
1 Post
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
hey i installed my Johnson Pump on Tuesday... i didn't splice any wires... all i did was pop off the circuit/ electrical connector from the Bosch unit & added it to the Johnson... the Connector from the Bosch pump is labeled which is + and - so just connect the red wire from the Johnson to the + prong of the connector and like wise to the other prong... and seal with electrical tape. plug in and go...
#37
07 E550, 02 C32, 91 300E
Great info! This should be stickied or something since literally every C32 is going to need it at some point.
pshek: haha, man just get a used iwaki return pump from someone who is parting out their tank. I wouldn't risk my fish and corals to that bosch pump...especially with how often it seems to fail (not to mention the coolant mentioned before).
#39
Super Moderator Alumni
