Belt size?
hey guys! It's time for me to replace my serpentine belt. It's starting to show some cracks. I've tried to search the site, but I keep getting either a blank screen or a server error message. I also looked up and down the internet and nobody lists anything available for it. I've also tried a few local dealers and they cant give me a size, only a part # which doesn't cross over and I cant figure out the size. Does anyone know what size the belt is on the C32?
In case your asking, I don't want to buy it from the dealer just yet, since I have a gift card to a local parts store and was wanting to use it first, since our belts are a little pricey. |
114.25" and the only place you are going to find one is the dealership.
got a part number on it?
Originally Posted by calimax
(Post 2503372)
Originally Posted by edtv82
(Post 2504804)
the dealership here in dayton refuse to give out part numbers
Part number is 112 997 00 92. |
thanks for the #.... the dealership here is like the only one unless you drive an hour either to columbus or the Cincy area..
but thanks again :y |
If you had the EvoSport pulleys you can run the Goodyear belt which is slightly longer than the stock one. It just takes the right pulley combination.
oh snap, I had a totally had a brain fart:duh:, I'm using the RennTech Pulleys. Looks like I'll have to pull it off then shop around. Does any one make a better quality belt than the Goodyear Gator Back or Gates?
Guess the dealer one wont work after all! |
I think the RennTech pulley's use the stock belt. If not they know the size.
renntech pulleys use the stock size belt
