want to buy c32.
Old Dec 1, 2002 | 09:22 PM
pocholin's Avatar
Volvo V90 CC
Originally posted by c32brabus
where is this track located?
the one pocholin is talking about?
and since when do c32s run 14sec timeslips ???????????
if the elevation is high at the track that may cause a prob. but nothing that cant be fixed.
E55s are naturally aspirated so elevation doesnt make difference, however c32 are supercharged so the air density makes a big difference since its lower at higher elev. the car tends to starve for oxygen. My audi S4(twin turbo) has the same prob.
Solution: just reset the ecu at that particular elevation and let it relearn for about 10-20miles.
so where's this track located ....? check the elevation.
Houston Raceway park, it most be about a few feet from sea level, probably not more than 50 ft. if you take any road from there it will take you 8 minutes to hit the sea.
Old Dec 1, 2002 | 10:31 PM
c32brabus's Avatar
the problem can occur vice-versa too. so best thing to do is reset the ecu at that elevation and run the car on test mode so the tracktion control is totaly off.
Old Dec 3, 2002 | 03:13 AM
rrf's Avatar
rrf
but, don't dis the C
Good run Poch!
But maybe we better send in our Houston Resident, el Senor Roozy, to hold up the reputation of the C32
He has a couple of decent slips from that track too.
http://www.eliteviews.com/amg.htm
Old Dec 4, 2002 | 12:49 AM
pocholin's Avatar
Volvo V90 CC
Re: but, don't dis the C
Originally posted by rrf
Good run Poch!
You'll have to wait for roozy to get his car. He wrecked that one and has a new 2003 in order, it should be here already!
He and I have talked and agreed to go race, my times are still barely better, scary !!!
Old Dec 4, 2002 | 01:09 AM
amgme's Avatar
07 SL550; C32 (sold)
oh my! how did roozy wreck his car?
Old Dec 4, 2002 | 08:49 AM
pocholin's Avatar
Volvo V90 CC
Not sure, but he flipped it over
