car wont go into drive!!! need help
Old Jan 22, 2008 | 12:09 AM
amgstyle's Avatar
2002 SLK 32 AMG
hey guys, after work i started my car to go home but when i pressed the brake to put the shifter in D, i wouldn't move. i tried it over again couple of times but it won't go into D. it seems like it's stuck in P. can anybody help with my problem. for me to put it into D was i had to stick a thin metal thing into the slot next to D.
Old Jan 22, 2008 | 08:59 AM
john89011's Avatar
MB C32 AMG
Did you try to remove the little coin holder next to your cupholder and sticking in a screw driver? Check your manual
Old Jan 22, 2008 | 04:15 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Also try shaking the steering wheel left and right while shifting
Old Jan 22, 2008 | 04:33 PM
CynCarvin32's Avatar
Mercedes Benz
Sounds like your shift interlock is broken. The switch that lets the shifter come out of park when you depress the brake can break and this is what happens. I had this happen to my 2001 S55 while in an underground parking garage. The tow truck could not get the car out due to the confined space so the tech had to come fix the car in my parking space!
Good luck.
There is a way to manually over ride the system but in my case the manual over ride was not an option because the car was purely electrical in nature and the switch would not open regardless. I think the W203 allows for manual over ride of this safety feature.
Old Jan 22, 2008 | 10:11 PM
Quick Silver's Avatar
2019 CLS450 4matic, 2013 CLS550 4matic (totaled), 2005 C55 (traded), & a Ford F150
That sucks. Wish I could offer some advice.
