19" Wheel Fitment Question
2012 CLS63
Ok so Ive searched the forums and cant find a difinitive answer and since my W209 forum is slow I thought Id ask in here since our wheels are a direct swap. Will these wheels fit our cars:
19x8.5 et 33 front and
19x9.5 et 40 rears
Please notice the width and the offsets
Your could help is appreciated
Thanks in advance!
19x9.5 et 40 rears
Thanks in advance!
a quarter mile at a time
yeah - ET35 for the rear.
https://mbworld.org/forums/showpost....67&postcount=7
depending on the design of the wheel and tire size, you MIGHT be able to go back and forth a couple mm, but not much. Not 100% sure on the W209, but on the W203, there isn't much room at all once you put 19" in.
MBworld Guru
white and whiter
for the 209 19x9.5 rear you can go ET30-35 without a problem. the rear wheel well has more clearance than our 203.
front depends on the wheel style they may or may not clear the 4-piston caliper which you have on the 500 for the front wheel.
2012 CLS63
Will I have a problem with the 40 rear and a 5mm spacer?
