LET HE?: WHAT DO I FILL WITH? WHAT IS THE BEST COMBO?
What is best used for getting the best performance(cooling) and the best protection for parts and boiling/freezing? Is there a best combo to use, or is it all going to be about the same? Also, if anyone has had good experiences with any specific products that help keep things cooler, please list them.Thanks in advance to everyone,
Bobby C.
Bobby C.
Generally speaking, it is not advised to use the aftermarket coolants in our cars (i.e. Peak, Prestone, etc.) - IIRC, it has something to do with the chemical composition of the MB specific stuff being matched to our cooling systems; the others are generic. Perhaps some other forum members can speak to this specific issue more directly...
Water is virtually unsurpassed at absorbing and dissipating heat. A shortcoming is its distinct lack of corrosion inhibitors. If freezing temperatures are a part of your annual routine, an appropriate percentage of Ethylene/Propylene Glycol is obviously essential to avoid expansion failure.
https://www.mbwholesaleparts.com/Sta...iFreeDec04.pdf
The aluminum intercooler core has been proven to be particularly prone to failure from corrosion-induced leakage. Because OE and aftermarket replacements are not inexpensive, it’s false economy to attempt chemically-induced improvements to heat dissipation through the cooling medium, imho.
Ashland refines and packages MB’s (G-05 derived) HOAT blend for us Yanks.
My air-water set-up doesn't encompass anything stock
sorry, for hijack
-drew
So in short, about 15% MB antifreeze+a bottle of water-wetter and 85% distilled water? Or maybe a little different like 20/80 or 25/75? I want the most cooling i can have that will also protect the engine. Right now with my PEAK 50/50 coolant (do not add water kind) I do not notice much of a difference between the original HE and my new LET HE?
Can someone PLEASE HELP me out on some options or different products or something that will make my bigger HE work a little better?
My results ended with an average 10 degrees less in coolant temp.
Oh yeah, I use the MB anit freeze and distilled water in mine. 40/60 mix.
See yeah
