Sputter resolved - Magnecor Wires faulty
C32 AMG
I recently purchased the Code3 SC pulley and intake, installed it and the car developed a splutter along with a few CEL codes (p2050, P2051, P2055).
At the time I thought it was the C3 SC pulley belt slipping or perhaps needed an ECU tune.
In any case I got the Jerry tune and still had the same problem. So I thought I'd check the spark plugs. After scrapping a few knuckles, they all checked out ok, so I thought I'd change the wires/leads back to original.
Surprise, surprise, the sputter disappeared and car drove great. It was those damn Magnecor wires. Be warned.....
Thought I'd share and let you all know.
C32 AMG
so tuning is not necessary for the crank and kompressor pulley combo?
i just ordered code3 stuff, if tuning is not necessary, might go on the hunt to find 178mm crank pulley
C32 AMG
Tuning - recommended
The tuning wasn't needed to resolve my sputter issue however I'd certainly recommend tuning for that set-up to ensure the A/F ratio's are ok.
I'm actually getting a dyno later in the week to check all that and then Jerry may modify the ECU file depending on the results.
The car does feel stronger with the ECU tune and it's safer too, otherwise you could be leaning out it high RPM.
Search the forum or post to see who is using that combo without Tune and ask them their personal recommendations.....talk to Brandon from C3P about your question or call LET and ask there advice cause I believe they delt with that situation.
The car does feel stronger with the ECU tune and it's safer too, otherwise you could be leaning out it high RPM."
Now he does not say he is using the SC and 178mm crank pulley combo he says the SC and intake combo
2002 C32 AMG
This seems to be a common issue with Magnecors. I had them on my Talon TSi, and after about a year, they were shot. It took me a little while to find the problem. They were the last things on my checklist since they weren't very old.
***IF YOU HAVE MAGNECOR WIRES, AND ARE EXPERIENCING PROBLEMS, CHECK THEM FIRST!!!*** Your plugs will outlast the wires.
