TSW Bremma Situation -- what to do??
Old Apr 11, 2009 | 02:21 PM
AMG Sleeper's Avatar
2005 C55 AMG, 2010 VW GTI (Stage 1)
hey guys,
I dropped off my car yesterday to get my new T1Rs mounted on the front wheels... but the techs discovered both fronts and 1 rear are allegedly "bent" - the cost i was quoted was $150 per wheel to repair.
Basically I want to see if you think it's worth it to fix the 3 wheels or just shell out the extra cash and buy new ones? any experience with this?
Second question -- anyone recently buy TSW Bremma wheels? I have 19x8.5 front and 19x9.5 rear - any suggestions on best prices for these online? I thought I saw some members get them on here recently...
As always, your feedback and help (and links to wheel retailers!) with this is greatly appreciated, as my tires are fading and I need to make a decision about the wheels basically by Monday.
Thanks in advance!
Old Apr 11, 2009 | 06:42 PM
c32used's Avatar
LET C32 2002
Wow $150...if you look on discountTire.com they are just shy more new I believe. Here is a chrome rear
http://www.discounttire.com/dtcs/fin...8120&rc=ILCINT
also try tirerack.com
Old Apr 11, 2009 | 07:25 PM
JonMBZ's Avatar
06 C55, 09 E350
I would buy a new one. Repaired ones tend to have more issues down the line.
Old Apr 11, 2009 | 08:26 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
I think you should check around and you'll probably get some much lower prices to fix them. Also check Craigslist.
Old Apr 11, 2009 | 08:36 PM
RedG's Avatar
a g
$150 sounds about average to repair and refinish a bent wheel, especially aftermarket, and 19".
Why does everything have to be so cheap with everyone? Don't you want quality of work on your Mercedes, not shoddy cheap garbage?
Assuming his wheels are chrome they aren't worth the repair, unless it can be done without damage to the chrome (which is VERY hard to safely do. Other than that, being that they may be NON-chrome, its even more useful to just buy new wheels, and let someone else fix them.
Also TireRack.com doesn't sell TSW.
Old Apr 12, 2009 | 12:31 AM
sorry, i should've noted that they're non-chrome. sounds like the consensus is to get new wheels and have someone else fix the bent ones for cheaper...
but next thing i'm wondering is, can i find a buyer for the repaired rims after the fact?
thx!
Old Apr 12, 2009 | 01:08 AM
JonMBZ's Avatar
06 C55, 09 E350
ebay if anywhere, but most likely you will just end up recycling it for around 20-40 $
Old Apr 12, 2009 | 10:52 AM
RedG's Avatar
a g
thx!
Yes, non-chrome on Discount Tire online they have them at $161 brand new (though it did not list the front 19x8.5s).
As far as a repaired wheel? When done properly it will be as good as any other wheel.
Old Apr 13, 2009 | 07:05 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
$150 is pretty high for repairing per wheel at least it is for SoCal.
Old Apr 13, 2009 | 07:38 AM
viper501's Avatar
06 C55
I'd say that the TSW's are going to be *heavy* low pressure cast Chinese crap. Of course, I could be wrong but at that price point for a chrome 19, I'd be surprised if I was.
I'd shop around to see if a) they are really bent and b) if you can find a less expensive place to do the repair. Otherwise, get a good set of wheels and invest a few more dollars.
Old Apr 13, 2009 | 08:27 AM
SilverBulletAMG's Avatar
C32 AMG
If you can buy new for only a few $$ more than the cost of repair, that's a no brainer - buy new ones. As viper mentioned, at that price point you're going to get what you pay for. Less than $200 per rim is stupid cheap, although ebay has some great deals on used authentic rims you may want to look into.
Out of curiosity, where did you buy your current bent rims? I assume you can't just return them or you would have?
Old Apr 13, 2009 | 10:37 AM
bought them online 2 years ago - not sure which retailer though
yeah i think i need at least a second opinion. i'm also looking into maybe just shelling out some extra $$ and getting a different set of AMG rims altogether...
thx for ur help guys - i'll keep u posted
Old Apr 13, 2009 | 12:00 PM
quick question - will these fit?
http://cgi.ebay.com/ebaymotors/19-St...3A1|240%3A1318
i know the 19x8.5 and 19x9.5 is the right size, but not clear if offsets/bolt pattern will be an issue??
any offset/bolt pattern expertise would be much appreciated!
Old Apr 13, 2009 | 01:30 PM
viper501's Avatar
06 C55
"Low Pressure Casting Technique" = China = heavy
Old Apr 13, 2009 | 01:52 PM
so the 5x112 bolt pattern is correct?
also, what do u guys think about these wheels: ST5
Old Apr 13, 2009 | 02:29 PM
viper501's Avatar
06 C55
One of the things you need to keep in mind is that the low cost, low pressure castings are not going to be as durable as a decent high pressure or forged wheel. You're more likely to bend another wheel, or two or three, if you go with an inexpensive wheel like this.
As to the look of the wheel, I think they look nice. I like the five-spokers a lot. Makes cleaning a lot easier as well.
Old Apr 13, 2009 | 06:28 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if your point is about the weight of the wheel point taken. if your point is mainly to bash on made in China products then please save it to yourself. mention it once is more than enough.
fun fact: Brabus, Lorinser, Carlsson all had used low pressure cast. most of their wheels are still 29-30lbs in 19x8.5 19x9.5 sizing. AMG also uses LP casting. In fact most of the OEM wheels are LP cast. what high pressure cast are you talking about? You should toss your oem AMG wheels in the trash since your wheel is made from the same process as those made in China.
direct quote from tirerack
One-Piece Cast Wheels
This is the most common type of aluminum wheel. The casting of wheels is the process of getting molten aluminum inside a mold to form a wheel. There are different ways this can be accomplished and although it sounds simple, this is truly an art when done properly.
GRAVITY CASTING
Gravity casting is the most basic process of pouring molten aluminum into a mold utilizing the earth's gravity to fill the mold. Gravity casting offers a very reasonable production cost and is a good method for casting designs that are more visually oriented or when reducing weight is not a primary concern. Since the process relies on gravity to fill the mold, the aluminum is not as densely packed in the mold as some other casting processes. Often gravity cast wheels will have a higher weight to achieve the required strength.
LOW PRESSURE CASTING
Low pressure casting uses positive pressure to move the molten aluminum into the mold quicker and achieve a finished product that has improved mechanical properties (more dense) over a gravity cast wheel. Low-pressure casting has a slightly higher production cost over gravity casting. Low pressure is the most common process approved for aluminum wheels sold to the O.E.M. market. Low-pressure cast wheels offer a good value for the aftermarket as well. Some companies offer wheels that are produced under a higher pressure in special casting equipment to create a wheel that is lighter and stronger than a wheel produced in low pressure. Once again in the quest for lighter weight, there is a higher cost associated with the process.
Old Apr 13, 2009 | 06:33 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
they look pretty good.
yes the 5x112 is correct.
Old Apr 13, 2009 | 08:59 PM
viper501's Avatar
06 C55
Chill Frank. No China bashing going on. I know that the OEM amg wheels are l.p. cast. Or at least that is my suspicion with no verified confirmation.
My point is that if he is going to spend the money, look for some decent hp cast or forged wheels, even if he buys used, rather than blowing money on heavy, soft, poor quality wheels. Yeah, there are a lot of things that are manufactured well in China but low pressure or gravity cast wheels are not one of those things I want to stake my C55, much less my or my family's lives, on.
BBS, for one, uses HP casting on some of their wheels. I had a really nice set on a former car. Very light weight and never had a problem w/ bends despite rather crappy roads in my area.
Old Apr 14, 2009 | 10:18 AM
thanks for the all the feedback - so if i'm understanding this right, are the ones i linked to similar in casting (low pressure) to the OEM AMG wheels?
also, i've been surfing thru the Picture Thread to see what different rims look like on the w203 (i have silver bremmas and i also like the c63 style), but haven't found black bremma rims w/ polished lip on a silver w203 yet... any links out there i'd appreciate it!
Old Apr 14, 2009 | 07:07 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
$120 per wheel vs $500-1000 per wheel makes a lot of difference in "going to spend the money". Unless they're really chasing performance not a whole lot of people will want to spent while they can get something that looks good and cheap to replace.
Old Apr 14, 2009 | 08:34 PM
c32used's Avatar
LET C32 2002
Exclamation
+1000000000
Old Apr 15, 2009 | 10:35 AM
my thoughts and intentions exactly. thx frank!
has anyone had experience with Sport Edition wheels before?
something interesting i learned from speaking w/ discounttiredirect -- their "replica wheel" design line are proprietary molds that are forged by TSW -- meaning it looks like the TSW rims AND is literally the exact same quality because they do it especially for discounttire to sell under their own line.
i'm either going with the Replica Wheel AMG Twin to replace the Bremma (discontinued) or getting the Sport Edition ST5. i'll let u guys know and post pics when i'm all decided and ready to roll... thx!
Old Apr 15, 2009 | 08:32 PM
RedG's Avatar
a g
I've put quite a number of sport edition wheels on vehicles. Put some on a CLS55 the other day infact.
Old Apr 16, 2009 | 03:31 PM
that is VERY helpful to know. much obliged!!
