Tail light removal
Tail light removal
Anyone have links to a pdf file or instructions on how to take them off? I wanna see how my oems (painted black) look on it...
I have the disc (cant get it to copy over)-it looks like removing the liner around the light-there are screws and thats it (wire connections)-nothing fancy to get them out!
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
its really easy, there are like 4 bolts per side all accessible from the trunk. Pull the trunk liner back and you will see them.
03 C32 AMG
MBworld Guru
white and whiter
you can pull couple tabs that locks onto the liner to the trunk entry trim and pull the liner back.
OR the proper way i usually do which is take the entire trunk entry trim off and then the liner will be easy to move out of the way. takes longer, but makes it a lot easier without fighting with the liner for space.
