K-sport pro coil overs !!!!!
Old Jul 10, 2009 | 10:39 PM
jayton41's Avatar
05 C55 & 06 C230 SS
hey guys i was doing sum research and i found these
they are coil overs and usually coilovers are to soft for track use but look at this video
http://www.youtube.com/watch?v=-A2vEOgKkoQ
these coil overs look stiff enough for auto-x wat do u guys think????
Old Jul 11, 2009 | 03:46 AM
1qikctr's Avatar
Merc power
If your going with JDM suspension, please save urself $ and time TEIN is the way to go. If your doing Euro suspensions, go with H-R, KW, Pss9s.
Old Jul 11, 2009 | 05:56 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
there fine. i have d2's on my car and there basically the same coil over just stiffer spring rates since they all come out of the same factory in taiwan. I think its a pretty good coil over for the $1k range since it comes with adjustable damper. I would say there a good canyon running type of sprited driving on the street coil over.
If your serious about autox, i would pony up the extra money and get the blisteins.
I say the teins are over rated. these in my opinion are about on par with the teins. This is coming from my tein experience with my hondas.
beware though, if you have 19's the fronts leave barely a 1finger gap at the highest height if your using a 35 side wall.
Old Jul 11, 2009 | 11:23 AM
moosejaw's Avatar
none
agreed go with a euro setup H&R, Blisteins, KW, Ikea etc......
Old Jul 12, 2009 | 02:09 AM
jayton41's Avatar
05 C55 & 06 C230 SS
yea but i need sumthing stiff enough for the track
Old Jul 12, 2009 | 04:46 AM
TemjinX2's Avatar
you got your answer, get blisteins if your gonna track.
Old Jul 12, 2009 | 10:06 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Where have you heard/read that coilovers are usually too soft for track use?
You're getting good advice above - the only missing element is "what's your budget for suspension?" If it's not an issue, then perhaps contact JRZ or Moton and get a custom-spec'd set of coilovers for your track car... be prepared to pay ~$5k or more. If you're more comfortable in the $2k range, then Bilstein PSS9 or KW V2 is likely your best bet. If you'd rather stay in the $1k range - perhaps H&R springs and custom-valved Koni sport or Bilstein sport shocks/struts, as recommended by some track-oriented members.
Keep in mind, many folks here knowledgeable on such matters state that upgraded sways will make the most noticeable improvement in the on-track handling prowess of w203 AMGs... hope to put that theory to the test with my own, in the near future.
Old Jul 12, 2009 | 01:14 PM
AnimC32's Avatar
C32 AMG
Another option for 1k is Vogtland Sport Lowering Springs + Bilstein sport shocks
Old Jul 12, 2009 | 10:45 PM
jayton41's Avatar
05 C55 & 06 C230 SS
pss9 ??
Old Jul 12, 2009 | 10:47 PM
jayton41's Avatar
05 C55 & 06 C230 SS
thanx bro so what do u think is better h&r & koni set up or pss9 ???
Old Jul 14, 2009 | 10:21 AM
c32AMG-DTM's Avatar
Better? From everything I've heard and read of other's experiences, hands-down the PSS9 is better. It's also ~2x more money for the hardware vs. most spring/shock/strut offerings... so it should be.
Bottomline, only you can determine if the incremental cost will yield tangible, useful benefits for your application - but I hope the info helps you make that decision.
