anyone have a supercharger removal or intercooler install diy?
Old 07-20-2009, 03:52 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Originally Posted by 1qikctr
Looks like you got your weekend time right there. I'm tooo lazy to diy for something like that, talk about lazy *** who loves modding haha.
yeah it took be about 3 days...with me taking a lot of breaks because of the 100degree heat. I wait till night time mostly so i can work in 75degree weather. But yeah i definately would've went a lot faster if i had a extra pair of hands.
I just gotta fill the car with coolant tomorrow..i'm hoping everything works out.
Old 07-21-2009, 03:44 AM
TemjinX2's Avatar
hey guys,
everything is back together. The car starts, but makes a loud screeching noise at idle and the car idles at 3000rpm. I'm gonna try a ecu reset, but can the screeching noise from a bad belt? the belt i have now is oem and looks ok. But some people have said it can still be bad while looking good.
Would a bad belt explain my 3000rpm idle?
Old 07-21-2009, 03:46 AM
jturkel's Avatar
02 C32 AMG
i've heard of loose ignition wires causing this. not sure about a bad belt. is it a metallic screeching sound? getting any codes?
Old 07-21-2009, 03:47 AM
TemjinX2's Avatar
yeah its a loud metallic screeching sound. No codes. when you mean ignition wires...are you talking about the wires from the coil packs?
MBworld Guru
FrankW's Avatar
white and whiter
did you loop the belt correctly?
Old 07-21-2009, 03:49 AM
TemjinX2's Avatar
i believe so, the belt doesn't really move that much from its original spot when its detached.
Old 07-21-2009, 03:54 AM
  #32
TemjinX2's Avatar
josh might be right about the loose ignition wire...could also explain my 3000rpm idle.
Old 07-21-2009, 03:57 AM
  #33
MBworld Guru
FrankW's Avatar
white and whiter
i was messing around with ignition wires past few weeks. they definitely don't cause higher rpm.
i would think it's an issue between your throttle position sensor and throttle body controller. some where in between there's a short. I would check the wire for the throttle body. make sure it's properly connected.
Old 07-21-2009, 03:58 AM
  #34
jturkel's Avatar
02 C32 AMG
yes i was referring to the ignition wires. i've heard many members have a high or rough idle and it was because of loose wires. make sure you here that "pop" when you put them back in. its hard for some of them in the back.
Old 07-21-2009, 03:59 AM
  #35
jturkel's Avatar
02 C32 AMG
but i suppose this sounds good too, and you were messing with the TB IIRC
Old 07-21-2009, 04:00 AM
  #36
OverDrive's Avatar
Volvo
Had a smaller issue, It was a vacuum leak, I forgot to hook up one of the vacuum lines to the PCR Valves so it would idle very high at idle. Check your lines. Not sure about the noise from the S/C, are you sure its from the belt of the s/c it self?
  #37
jturkel's Avatar
02 C32 AMG
where is this metallic screeching sound coming from? a certain point on the belt loop at a certain pulley? or is it coming from within ur supercharger?
Old 07-21-2009, 05:20 AM
  #38
TemjinX2's Avatar
i've was actually gonna replace the throttle body cable but the new cable i got is a lot shorter then the original one so i shelfed the idea. you might be right
Old 07-21-2009, 05:21 AM
  #39
TemjinX2's Avatar
i just checked it out...everything seems to be ok.
Old 07-21-2009, 05:24 AM
  #40
TemjinX2's Avatar
hmmm well the only hose that i didnt have one was the driver side crankcase ventiliation hose. i fixed it with one of those hose menders, you think its still linking from that hose? i guess i'll double check the hoses again.
Old 07-21-2009, 05:26 AM
  #41
TemjinX2's Avatar
well i replaced all my idle pulleys. i know my tensioner pulley is going bad but it was never been that loud. Its usually loud during the cold start then the sound goes away. i'm not too sure if its coming from the belt or sc charger. i might just change the belt since i have a extra one anyways.
Old 07-21-2009, 11:08 AM
  #42
///AMG4EVER's Avatar
CLS55 Designo 030
TemjinX2 - I have to agree with OverDrive. It's a vacuum leak.
Get a piece of hose and play Doctor with the car; try to diagnose where the noise is coming from. Since the C3P unit is not the same dims as the OEM you might have a leak by the surge tanks or by any of the sensors on the IC.
The loud noise and the rpm at 3K explains this as the ECU is not reading the correct delta X across the system. If you drive it or gas it, you are more than like going to get a CEL code. P0105 is very common since it gets trigger when the MAP is out of range.
A couple of questions that can help you get to the source...
1) When you gas the car, does the chirping sound goes away?
2) Did you use phenolic spacers at the surge tanks?
3) How did you install the MAP and IAT sensors?
Old 07-21-2009, 02:01 PM
  #43
TemjinX2's Avatar
The loud noise and the rpm at 3K explains this as the ECU is not reading the correct delta X across the system. If you drive it or gas it, you are more than like going to get a CEL code. P0105 is very common since it gets trigger when the MAF is out of range.
3) How did you install the MAF and IAT sensors?
yeah i installed phenolic spacers with the surge tanks. i'll try uninstalling the spacers.
The map and the IAT sensors bolted up to there oem locations.
Old 07-21-2009, 02:54 PM
  #44
CLS55 Designo 030
You need to make sure the surge tanks sit properly in the back. Adjust the rubber hose that connects the Y-pipe of the IC.
The MAP sensor is where your problem is... it appears it "bolts up" fine but in reality, the o-ring on the sensor does not sit flush (or tight enough) at the surface of the IC. You need plenty of gasket maker and create your own gasket in those 3 holes (by the MAP sensor) in order to make it work.
It's a PIA since you have to take everything out again but it's more than likely your solution.
Old 07-21-2009, 03:23 PM
  #45
jturkel's Avatar
02 C32 AMG
^the c32 has a MAP sensor, not a MAF sensor
Old 07-21-2009, 03:49 PM
  #46
TemjinX2's Avatar
The MAF sensor is where your problem is... it appears it "bolts up" fine but in reality, the o-ring on the sensor does not sit flush (or tight enough) at the surface of the IC. You need plenty of gasket maker and create your own gasket in those 3 holes (by the MAF sensor) in order to make it work.
i'll try adjusting the surge tanks first...i'm just waiting till it gets cooler since its 100 degrees at the moment. thanks for your suggestions.
Old 07-21-2009, 05:38 PM
  #47
CLS55 Designo 030
Correct. Revised.
Old 07-25-2009, 06:39 PM
  #48
TemjinX2's Avatar
just to give an update..i think the metal screeching sound and the vaccum leak were two separate issues.
i replaced the tensioner idle pulley and the screeching sound went away.
I decided to take everyone's advice. i reinstalled the throttle body, map sensor, y splitter. I think it was a combination of the throttle body and loose map sensor.
I would like to thank splinter for all his help and for convincing me not to give up and everyone else that gave me great input.
Anyways the cars running strong...i'm pretty psyched. i just need to drive it around a bit and make sure the intercooler is fully bled.
Old 07-25-2009, 09:16 PM
  #49
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Pleased you’ve squared things away. Perseverance FTW. Congratulations.
Quick Reply: anyone have a supercharger removal or intercooler install diy?
