Any advice is GREAT!! C32 AMG
if you havent had a glycol test how do you know its leaking? is the trans jerking? if you have glycol issues the trans is already in trouble. if your just doing precautionary you can do the whole thing for under 400$
You basically just pump out the the tranny fluid and drop the pan under and change the filters and refill.
Here's the link to the diy
http://www.installuniversity.com/mb/...on-o-ring.html
Splinter wrote a great diy on the radiator change on the w203 forum
C32 behr radiator for $160 shipped.
http://cgi.ebay.com/ebaymotors/Merce...s#ht_945wt_844
Think logically for a second. Do you think you can get more metal shards out by having a vaccum suck out the fluid from tq converter or letting the metal shards and debris drain by gravity into the pan?
Also when you do a change, you don't get out all the fluid from the tq converter so the new fluid mixes with the old fluid.
Thats why when you do a flush, you change the fluid. Drive it around and suck out the 4qt and put in new fluid. Then drive it around and suck out another 4qts and put in 4qts new fluid.
Do you really want keep jack up your car on jack stands 3 times in a row just for a flush?
The dealership also sucks out the oil and tranny fluids. They never use the drain plugs. Its quicker and you get more debris out when you get it sucked out.
